A lot of the "stealth" missions if you have double jump, maybe some upgrades to increase the time before you are detected, and have a decent amount of health, etc. you can "stealth" them by just moving quickly through the map and disabling the odd camera - usually it is flagged on body count which can be avoided that way as you just shrug off anything attacking you and/or moving too quickly to be detected and sometimes it is flagged on if a camera detects you.
(Most mission won't actually fail you anyhow for not using stealth, just reduces the rewards of which you generally have plenty of).
Stealth I found too tedious to be worth it - too many glitches and bugs, hidden flags/timers, etc. in the stealth mechanics along with some elements of stealth having massive tolerances before you are detected and others such a fine line you struggle to do it by skill.
