Why is he allowed to continue?
If we go down that road there are a few who should have their right to post here revoked.
Half of this thread or so seems to consist of AMD 'enthusiasts' gloating, baiting and mocking Intel users and chips.I motion that Dave now gets banned from the CPU section. Simply ignoring him is insufficient as his tripe derails threads to such a degree I get pages of half conversation, totally removing any sense these threads make.
His presence is outright disruptive, with a plethora of veiled insults thrown into the mix. Why is he allowed to continue?
Ive also seen his veiled insults and actually told him to stop them i thought personal attacks wernt allowedI motion that Dave now gets banned from the CPU section. Simply ignoring him is insufficient as his tripe derails threads to such a degree I get pages of half conversation, totally removing any sense these threads make.
Because they are so fast out of the box there is no need to OC them so the program is futile?Intel has announced it is shutting down its overclocking protection warranty program just before the realise of Rocket Lake - mhm I wonder why![]()
Dave is merely the pertinent example. And yes, there are quite a few people who'd be on the same list.If we go down that road there are a few who should have their right to post here revoked.
That is literally not what I said and you know it.Yep, definitely ban anyone you disagree with
You'd think, but half the moderation these days seems to consist of just deleting the bickering, not actually doing anything about the cause of the problem.Ive also seen his veiled insults and actually told him to stop them i thought personal attacks wernt allowed
There goes the AVX-512 exclusivity!
https://hothardware.com/news/amd-epyc-7004-zen-4-cpus-avx3-512-bfloat16-instructions
Right
"AVX-512, or Advanced Vector Extensions 512, can require quite a bit of power and generate considerable heat in some cases"
This is why they state TDP up to hellish 400 watts!
Tbh that isn't really an issue, it is same with any chip that full utilise AVX-512 would be the same and the relevance for anyone whom was on Epyc before would still be seeing same/similar TDP usage anyways. If you change workflow to allow for AVX-512 and all that then you will be updating other systems and tbh a 96 core CPU at 400 watt seems pretty impressive to me tbh. Also isn't it standard 350w up to 400w.
The standard is between 180 and 250 watts.
more numbers for the 11700k
firstly memory latency, we know it's causing issues in games but how bad is it?
The 11700k paired with 3600 CL14 memory with the interconnect in sync produces 57ns latency in AIDA64, much higher than the 44ns the same RAM on 10700k produces and nearly matching the 59ns I get on my Zen3 with the same clocks and sub timings.
Power draw: The 11700k uses 70w more power than the 5800x while gaming
Thanks for the insight.Further info: Now 90% sure that memory max is locked at 3733 sync which is pretty terrible for performance. The microcode is there to boost the voltage and bump up vid table to stabilize the platform. It’s not for performance. You won’t be able to clock mem high enough to make up for desync penalty. The issue isn’t the mem, it’s the interconnect being a choke point. No diff to zen in that respect.
unless something dramatic changes (it won’t) I’d get a 10900k. How cml performs on z590 still tbd.
It's a little troubling that you are finding this 3733Mhz sync limit which seems quite a retrograde move, though I'm curious as to the reason why it is necessary. Are the memory latencies you are seeing already in the low 40ns when you're at 3733Mhz?
The ability to tune memory without sync limits is the main reason that my tuned 9700K can still hang with my tuned 5800X in some lower threaded applications, though as we are a niche clientele then getting the most performance out of the CPU at stock is probably the priority - similar to what AMD have been doing.
Someone on another forum stated the latency might be because the "final" microcode hasn't been released yet. If this is indeed what latency will be like without any fixes that's a letdown.
Memory manufacturers must be kicking themselves if this is the growing trend for RAM being around 3,600. Sure you can bin RAM for 4,600+ but if nobody buys it you have to start putting the way higher chip grades in lesser units to satisfy demand.
