Is this the one I have?
https://imgur.com/a/nZcxOQx
The new sticks are product number TF13D432G3600HC14CDC01 for 32GB 3600 C14
Supply issues the weak pound or a giant octopuss prowling the South China Sea, take your pick.wtf happened to the price
I ordered some F4-3600C16D-32GTZN for 240 quid (probably similar bin to 8Pack but I'll gladly pay the slight extra for temp sensors). Won't be able to test it till other parts come in. Can also snap up the F4-3600C14D-32GTZR for £304 including import fees which for the best XMP dual rank profile on Ryzen isn't bad in the current climate. Not as many octopus I guess!
Can anyone tell me if the 8Pack kits have a temperatures sensor on them? Also are the 3600C16 and 3200C14 exactly the same just with different xmp profiles? Thanks!
No they don't and believe so.
No and yes
well it is easy to demonstrate that GDM on is FASTER than 2T GDM off, so I don't care what it essentially is.essentially 2.5T
Very strange. Comparing unstable settings (more stable means both sides of comparison are unstable). And to run 2T you need more configuring?2T GDM off is more stable and higher performance for me , if you know how to configure it
I know there will be people with MSI boards checking this thread so I'll ask here. It wasn't something I looked at when deciding on a board initially. One of those things you only notice until you actually have the board.
While waiting for my G. SKill 32GB kit I got some standard 16GB Corsair 3600 so I could test the system. I have the B550 Unify on 1.2.0.1 AGESA.
The DDR voltage control is strange. If you enable XMP or even specifically put in 1.350v it always states 1.352v. Here's the thing. If you open Ryzen Master that states the voltage is 1.36v... quite a difference.
hwinfo64 does state 1.352v but it's not a constant 1.352v (it is most of the time) but the maximum column gave me 1.356v. Now I know it's pretty hard to constantly regulate a static voltage to a component but this seems pretty weird especially given Ryzen Master reading. Checking YouTube the over voltage seems to be normal.
https://i.imgur.com/KN8FKCk.png (what I experience)
https://i.imgur.com/iXw7vKd.png (B450)
https://i.imgur.com/gtBQVLC.png (overclocker bios on x570 unify, wants 1.50v and it's giving him 1.536v....)
https://i.imgur.com/VGTCjG1.png (Buildzoid's X570 Tomahawk video)
Basically can anyone else confirm this behavior in BIOS and that Ryzen Master gives different readings? I don't know if MSI is supplying vddio to ryzen master from another value that is not just a straight plug reading from the value it should be sending.
