like I'm desperately trying
but it looks like the DVR was dumped with its last active configuration.
and anyway as far as the law is concerned things are traceable.Yeh in fairness I noticed someone nearby has an obvious wireless camera at practically head height on top of their fence facing into their garden.
If someone wanted to, they could walk up to it and rip it off and it's not even facing them.
I think I'll mount it inside the shed poking out a little or something so that it's less obvious / less easy to steal.
CCTV is a deterrent and if they want to get in they will just bally up and you won't even get any faces. Make sure the cameras are obvious, plaster the place with notices that it is in operation, and hope they go elsewhere, because even if you do get their faces clear as day, there's probably nothing going to happen as a result sadly.
Yeh I figured as much. If someone wants to get in, they will.
You just need to be the least attractive proposition.
I think round my way, they're just opportunists trying door handles and, if open, they'll probably jump in and look for some keys / wallets / cash.
I think it's only been car keys nicked with doors being unlocked around here.
Yes, it does.
@WJA96
Just checking if you received any emails from me sent one last week and the weekend , hope everything is ok ?
Thanks
I've got some lovely cameras in MM at the moment. If you have to mount the camera high up then a zoom is good as you can frame the image using the zoom. And for high up you want a strong illuminator - at least 50m.
Just checked my spam and yes, all good. I’m still very happy to schedule a zoom call if you want any help with the setup of your system.
PTZs are always looking the wrong way. That's the great thing about them. They sound like an excellent concept until you realise that they actually don't see very much so unless you're watching them constantly and can intervene and move them, then you'll never see very much. They tick that 'gadget' box really well.
There are camera systems that link a static camera to a PTZ so if the static camera sees motion in an area it pulls the PTZ to a pre-defined spot to look for what you want to see close up. But you won't get that for £250.
What you'll find in most situations though is that more static cameras make for a more reliable and thorough view of what you want to see.
Cheap PTZs have issues with drive belts, how many steps are on the drive belts and stepper motors (for smooth motion), how watertight they are (they have a nasty habit of freezing in place in the winter).
For prices - if you register for an account with Broadband Buyer you can see what they are charging for cameras.
