Well last 24 hours has been busy, did some fluid changes and undersealed the whole SRT8 with Lanoguard...
Oil that came out of the two diffs and transfer case was all good and in solid condition... whether it had ever been changed is another question and I can't see in any receipts it has... so rather than take a chance, just get it all done myself. Also, slapped 16 new Iridium Spark Plugs in as well so Big Ern is puring!
Could have been worse, you might have started the job then realisedYeah they're twin spark, something I never knew tbh until I'd bought one... so double the friggin cost hahaha... hey how, you can't take it with ya can you lol
Stickers and I'l be detailing all the black bits this week and just getting it all tidy in the engine bay. Hate oil and dirty... not good for my OCD lol.Looking good, when you say detailing, are you just using a paintbrush or is it some sort of vinyl sticker?
Well they came back out today and removed the remap as it showed zero improvement which is bad really as a lot of people would simply think they have more power and the placebo effect kicks in. Only reason I know is there was basiclaly no difference on a dyno and more importantly under my foot. if I can't tell the difference and then a dyno number backup, refund time lol@pugheaven any news on the remap, or did I miss a post?
Nope, it goes on everything, nuts, brackets, rubber piping absolutel everything under the car including control arms and suspension etc as it helps those things not degrade. Only thing we didnt' put it on was the exhaust for obvious reasons. However, everything else think coating. 2 hours worth of work... sprays on pretty easy and because it's a spray it gets in all the nooks and crannies. The one thing I may do is use the thicker grease for things like brake lines and add a little more on during summer ready for winter months. Checked underneath since doing it and it cures kinda like a think wax that you have to scratch to remove... fingers crossed it works. First major test will be this time next year when I do it again and see how it's reacted.Great job. You mask everything up like all the nuts and stuff before using the Lanoguard? I bet that took you ages?
Yeah I was kinda taking them as it was done so, by the time it was finished, everything coated. Fingers crossed it works well lolThanks. Only reason i thought you had is that every nut in your first picture hasnt been coated with the stuff so thought your had masked them off or something lol
Yep, bolted on with 3 screws underneath the bonnet.Is the bonnet bra removable?
