Thought I'd accidentally opened page 1 of the thread for a second thereMy Frankenstein abomination! (Rack Mount chassis)
*img snip*
Why aren’t you cooling the motherboard as well?
apparently makes only 2c difference and I'm not pushing the cpu at all. maybe some time if I have some spare fittings and the means to make the necessary tight turns...
Only one of your RAM sticks is lit up
My rig is pretty much complete. I've installed a Byski temp/flow sensor and might add in a bottom 140mm intake fan as the last thing to do.
AMD 5900x/6800XT all EK waterblocks. Alpacool Rads and pumps. EK/Barrow fittings. XSPX Dual D5 Res.
Mate, that's glorious.
So clean and love the tubing runs. You can barely even see them from the front.
May I ask, roughly how long you waiting to receive that Bykski digital flow meter?
I ordered from China a month ago and still waiting! I can see in tracking that it has moved every now and then.
I'm not convinced it's even left China yet.
When I get that I am rigging up an external 420mm radiator on the outside of the case for spits and giggles.
Thank you very much. The Byski flow meter arrived in about 14 days. Ordered directly from Byski store - Aliexpress.
There is one niggle with mine, when the waters up to temp (gaming for a few hours) you can hear the flow meter bearing its almost like its failing (its probably not) but it can be noisy and its doesn't happen all the time.
Have asked for a replacement so lets see what they say. Not to fussed about it but when you hear noise on a completely silent rig its annoying haha
I was thinking of doing an external rad setup exactly like that with an Alphacool Nova 1080 rad.
Monster of a rad but having already 2 decent rads money was best spent on the PC hardware.![]()
Super clean builds guys!
