Hi All,
Was wondering if anyone has done the thermal pad mod on the rear of their RTX 3080 FE cards to help with the memory hotspot temps and if so what thickeness pads did you use?
As I was wondering what thickness thermal pads are used elsewhere as they look pretty low quality ones so may as well replace them all while the back plate is off.
Thanks
Thanks
What trash thermal pads are Nvidia using?? I was expecting maybe 10c but 26c!
