Hang on, Intel ships air coolers for the non K versions, including the 11900 / 11900F apparently. If that's affordable, why not on the higher margin K versions?
Are the air coolers just not upto it on 14nm at higher clocks?
Yes.Also, can you run the 5800X with a low end /cheap air cooler if it's underclocked (+ undervolted) say 100-200mhz?
Yes.
You can even keep it in stock if temps of 95C don't scare you, CPU will do a decent job of downclocking itself when near thermal limits
ECO mode would turn it from 95W to 65W grade CPU. Or tune power limits manually to suitable levels.
Well, so far Alder Lake's leaks all fall in the category 'interesting' rather than fast.Intel is so behind and with there cpus intel need to do something special with alder lake to get back the performance crown.
The Linux kernel writers should be able to handle BIG.little fairly soon after release, but Microsoft's scheduler might struggle for a while though.
Ouch![]()
