Interesting might try this. Latest version is 2.0 RC5 released 09/03/21
https://www.guru3d.com/files-details/clocktuner-for-ryzen-download.html
(Delete previous Clocktuner folder as the archive contains a new version of CinebenchR20)
Installation:
You can now run the Cinebench R20 one time. Please accept the license agreement, and close it Cinebench R20. CTR is now ready for use.
- Download CTR and unpack the ZIP archive in a directory of your choice
- Then download the Cinebench R20 archive and extract the contents of the archive to the “CB20” folder (this folder is located inside the CTR folder).
Note: Sometimes it happens that the OS corrupts CTR configuration file and the application no longer wants to start. Below you can also download CTR Config Cleaner which will allow you to get rid of the corrupted file.
- A common mistake is that people forget to run the program as an administrator or forget to delete or disable anti-cheat software.
