Wish i could find a new 10700k for that ive been looking for a while and lowest ive seen is just under 300
they go up and down all the time as said they have been that low recently.
The Anandtech early review of the 11700K says this about the memory controller setting " For the avoidance of doubt, in our testing on every microcode to date, all of our motherboards were running at a 1:1 ratio". So, not looking good for Rocket Lake, considering the performance and UK pre-order pricing...
Also, now I'm wondering if there will be any problems running the memory controller at 1:1 at DDR 4 frequencies higher than 3200mhz...
I suppose we will need to see a proper review from Gamer Nexus, comparing the 11700K and 5600X / 5800X, to get a clearer view of how it compares.
Just noticed all of the Alienware Aurora systems are Zen 3.
Only on the UK site as the US still has both. Supply issues![]()
That's pretty huge, if Dell (Alienware is owned by Dell) is only using AMD in its gaming systems that is a big deal
Pretty sure its AMD chips with supply issues.
It's also not just the UK. They've probably dropped the Intel systems in lots of large markets because no one was buying them.
3200mhz is where the official memory support cuts off, no gaurantee to get over 3200mhz with 1:1 with the IMC. However there are a few people who have managed to get 3733mhz 1:1 but not a single person has gone higher, the IMC absolutely refuses to let the system boot of you go over 3733mhz
Limit eerily similar to Zen 2/3 memory controller. And much lower than previous gen.3200mhz is where the official memory support cuts off, no gaurantee to get over 3200mhz with 1:1 with the IMC. However there are a few people who have managed to get 3733mhz 1:1 but not a single person has gone higher, the IMC absolutely refuses to let the system boot of you go over 3733mhz
Except Zen 3 can now work up to 4000MHz if lucky.
Wonder how high clock 4000+MHz memory runs on Rocket Lake now. Will we have another "sweet spot 3600" case?
Wonder why Intel went this route, when previous memory controller would happily run up to 4500MHz without any sync/async penalties.very similiar to ryzen's memory architecture
I'm only just getting up to scratch with all the new stuff, but is this RL release just to give this new desktop architecture a shake out before the shrink?
The architecture was designed for 10nm. Because Intel can't get their 10nm production working adequately it was backported to 14nm and it appears to have gone poorly.
They've rolled it out anyway just to be seen to be putting out something new.
If I remember correctly, in the past Intel used to use memory straps or something like that. If you go over certain (predetermined) memory speed, motherboard would set RAM/mem controller ratio and would drop mem controller speed to keep RAM stable. That was long time ago though, back in x79/x99 socket days.Wonder why Intel went this route, when previous memory controller would happily run up to 4500MHz without any sync/async penalties.
And while on topic of old controller, why was the official supported speed capped so low for so long? 2933 even on top of line overclocker friendly models? Which now gets bumped to 3200 with a mile of footnotes and caveats?
They're not
nice ninja
Yep that USA market is tiny...
'large markets', wouldn't that be one of the largest? What about Japan, China, India, Australia....When did I say they dropped it in the USA?
