I had issues of screen going black when certian apps presented data such as WFC firewall alerts.
I observed the problem is caused by gsync.
Two fixes.
Either make custom profiles for the applications in question and in those profiles disable gsync.
Or probably easier, disable gsync on the base profile, and enable it selectively for games that benefit instead.
Ok, well as no one responded I've taken the chance and ordered said monitor.
Should be here next month!
What were the issues you were worried about anyway?Cant say I have had any, other than a very rare black screen during gaming for a second or so, gsync related.
I won't be using Gsync - so that's good to know. Will see what the colours are like when I receive it - looking forward to replacing my 144hz TN panel from Element Gaming, this should be a much better screen and performance!
It will feel like a massive upgrade from TN, my laptop is a small TN screen, and if I look from slightly too high the bottom is darker, if I lower my head so bottom is right colour/contract, the top is darker. The viewing angle is so bad.
I remember my panel progress.
TN - hated it from day 1.
VA - could finally watch movies without looking head on, but too much black smear and viewing angles still not good enough.
IPS - never looked back. IPS glow is a thing but if you like me and get used to not having super high brightness the problem is significantly mitigated.
Doing my head in this flickering, can't seem to work out what it is, sometimes it's fine sometimes it's really bad. Sometimes it's like the highest black frame insertion on some tvs where it goes really flickery and sickly.
So frustrating, this monitor looks like the best fit for me. But every time I come in here someone is complaining about another fault.![]()
I have 2 perfect ones, other than the 60Hz dark pixel line that every single monitor has. I don’t notice this though unless I look for it.
I've never run mine at 60hz - my pc is not realy good enough to take advantage of this monitor, but I just leave it at 165hz, adaptive sync/freesync - It doesnt seem to put any extra strain on my pc compared to 120/144hz.
