- 11 Dec 2002
- Darkest Norfolk
nice
- get that sticker off though!
- get that sticker off though!Arrived a few days ago, but only just had time to post:
seeing your nice steamed milk ... I was wondering what's the default tip is - online seems to be 3 holes, I can't see size ?
I previously posted, but, the 4x1.5mm dia I have (bezzera), gives me problems, too powerful;
seems some folks with marax went/recommend a single hole https://old.reddit.com/r/espresso/comments/k7584p/single_hole_steam_tip_on_marax/
which is probably what i'll try next.
Anyway - scanned an interesting marax thread about steaming ... looks like some are getting a software fix, for an issue where boiler might choose to refill during steaming,
dropping off the pressure https://coffeeforums.co.uk/topic/56880-mara-x-steam-issue/page/17/#comments
so might be interesting to experiment
more generally do most folks dump the pf water contents(post cooling) into the sink before filling with coffee ? or the drip tray ?
I'm about to embark on a project with my ancient Gaggia Paros ...
I'm not sure what I'll be doing with it overall...
Chuck some photos up when you do it - they are weird looking machines and pretty uncommon
I'd take a look at the PID options (think Mr Shades kit fits) as the temp stability, like the classic, is hit and miss.
ok a more defintive review is showing 2 x 1mm diameter holes , I have 4x1.52 hole steam tip. Still playing with it
I remember envying those ... they were really before prosumer existed , but I could only justify an original mk1 silvia(Audrey) and rocky.,I'm about to embark on a project with my ancient Gaggia Paros that had been sat abandoned for at least a decade,
would have thought their/gaggia build quality was better back then, silvia had a die-cast & ABS chassis.
Just googled it, looks pretty cool - will be nice to see it get up and going again.
Which one did you get?Finally resolved the Barista Express grinding and the mess it makes. All it needed was a portafilter funnel i grabbed off amazon.
They really should sort that and the inconsistency in the amount it grinds
https://coffeeequipmentreviews.wordpress.com/2020/03/10/lelit-marax-review-in-progress/
so the tamper will fit through it, according to amazon comments - can you still knock the pf on the side too ? I always do that.I just got one of these https://www.amazon.co.uk/Hands-Free...x=hands+free+dosing+funnel,kitchen,154&sr=8-4
Does the job perfectly - It's funny Sage haven't resolved it yet. Looks like other brand machines don't have the problem (delonghi specialista).
good - just the price tag - the blade of steam it will give is interesting (like my karcher)You seem to think about steam tips quite a lot, maybe it's time to invest in the Weber Workshops fully adjustable one
Stuck between the bambino plus and grinder vs the barista express - any thoughts? Bambino takes up less space but doesn’t “look” as good as the barista
