What should we be looking at here?
Shared the settings that I think are the best.
-Texture Filtering Quality should be set to High for maximum image quality;
-Anisotropic Filtering to Enabled with 16x preset.
-Anti-Aliasing Method to Adaptive multisampling;
-Radeon Image Sharpening to Enabled and 100% in Windows with Microsoft Edge as the running browser, and up to the user in the games.
What's the difference between Radeon Chill and Frame rate target control?
shows me the optional update without being in the windows beta channel, but the version is older than the current driver direct from AMD.
I've had a similar problem many times before. I'm pretty sure it's a timing issue where certain combinations of monitor+GPU wake up slow enough that Windows gives up and assigns the default driver to the monitor, limiting its resolution to something archaic. It seems to only happen with DP, so it's possibly related to the stupid DP autodetection that causes so many multimonitor problems....About half the times after the monitor wakes up from power saving mode, the resolution drops to 1280x800...
do you have a vega gpu and rift installed by any chance, this used to happen to me, didnt happen after the upgrade to 6800, but ive read it may be related to the rift being plugged in.Anyone else having issues installing 21.3.1?
It seems to install ok, but when it gets to the second part where the screen flickers off, it doesnt come back on. Have booted into Safe mode, wiped with DDU and reinstalled 21.2.3.
I've tried various times, but it seems consistent where it fails.
hopefully not the same thing, as it was bloody annoying and happens for a good 4 or so months at least. fingers crossed its a 1 time thing for you.I've got a Gigabyte 5700XT with a single AOC monitor - might try updating the monitor drivers and try again, purely because its the only thing I've not tried yet.
Currently running 21.2.3 absolutely fine, so will try again when the next one comes out - might just be an anomaly.
I can't offer a real solution, but cycling through the monitor's inputs may fix it quicker than turning it off and on again.
 don't suppose there's a way to edit the Windows timeout value? Or stagger the power up so that the GPU waits for a while until the monitor catches up first?Did that come out last weekRadeon Software Adrenalin 2020 Edition 21.3.1 WHQL
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-21-3-1
I installed my 6700xt on Saturday in the wife's pc and that's the driver it installed.No.
If you hover your mouse pointer over the driver download link, the date will be included in the file name.
