- 24 Feb 2021
Can someone recommend a good tutorial for undervolting and the tools required ? I’ve never done it before and obviously don’t want to screw up my PC. Thanks.
I was running 3600MHz - 14 15 14 14 28 @ 1.47 for a good year prior to introducing the 3080 in Jan.
Have a look at this video.
It's pretty simple really and you're unlikely to damage anything. Most of your time will be spent tweaking it to get it where you want. The only tool you need is MSI Afterburner.
Can someone explain to me.
I set curve as per instructions to 1800 at 850mv
But when playing e.g. Doom Eternal (running around 230fps) it says ingame its at 1815mhz??? Shouldnt it be at 1800?
Seems to be running around 70oC max 300wats and 42% fan speed around 44%
Thanks, I need to look at this also. So far I have used MSI afterburner for mining setup only.
I tried fixing the core but couldn't get it to stick so in the end am running using a 75% power limit, which in effect lowers the voltage I am assuming. But I have not setup a full curve, with performance in mind.Wierd, because if you are mining and not undervolting already you are throwing money away.
I really dont think its worth underclocking for such low gains in Power/Temp and losing the boosts up to 1920Mhz
Unless I am doing something wrong![]()
You don't have to set it to 1800. I've got a few profiles saved, one of which is 1950/900.
And as you noticed before if you have the thermal/power headroom it'll sometimes go up a 15mhz step even with the power slider at 100.
If you're on the edge of stability that 15mhz jump might cause it to crash. If you go too low with the power it might not crash but you could get stutter.
I'm sort of constrained by poor case cooling unless I want it to sound like a hoover but depending on the game I've got: -
1785/800 - much cooler for stuff that hammers the card
1845/850 - general stuff
1950/900 - easy to run stuff
Good idea - but wouldnt you want higher HZ for more demanding games (well apart from the noise)
