Also if running with Afterburner settings as per video it runs at 1800mhz solid
Default it is jumping around between 1800 -> 1920Mhz
Temps are around 73oC (3oC hotter)
Power 324W (24W more)
Fan Speed 46% (2% more)
I really dont think its worth underclocking for such low gains in Power/Temp and losing the boosts up to 1920Mhz
Unless I am doing something wrong![]()
Yeah I think you are doing something wrong. You should be getting less W not more.
I originally capped the frame rate to 74fps to match my 75hz monitor and I was around 60c in Zombie Army 4 with 225w or thereabouts @ 1920mhz (on 850mv).
If I let it run wild with the fps it was still only maxing at 250w think it was 160fps which is what I would expect and my temps were maxing at 67c.
Not really tried it with my new 144hz monitor but again I capped my framerate to 143fps so will see.
