Same here but beggars can't be choosers these days![]()
Yes, tbh I'm so glad I can exit out all these groups. I'm coming up from a 1070ti to a 3070. Big enough jump. Won't give me 4k but I was after better VR performance and this is plenty.
Try PartAlert that has been quite accurate for me for the FE drops.No notifications on Stock Informer discord group, is monitoring that a waste of time for FE drops?
3070 mate. With my birthday next week, this is a nice little present to myselfwhich card did you get ?
That should be a nice little upgrade right there.Yes, tbh I'm so glad I can exit out all these groups. I'm coming up from a 1070ti to a 3070. Big enough jump. Won't give me 4k but I was after better VR performance and this is plenty.
kept refreshing, came back with option to put in basket and I think I finally got one. 3070. Was after a 3080 but this will do.
I've bought a 3080FE and 3070FE. If you couldn't do it doesn't mean others will not be succesful.
Since the end of February? Because that's when the new rules of one card per IP/account/address/payment method were put in place. The limit was two cards prior to that.I've bought a 3080FE and 3070FE. If you couldn't do it doesn't mean others will not be succesful.
Below suggests otherwise. If you don't know, then don't say anything, easy.
Anyone undervolted their 3080FE?
What seems to be the sweet spot? Currently I've got a -280MHZ underclock with my 912mV dot set to 1920.
Is a banana yellow ?
850mv @ 1920mhz with +500 on memory
Thanks, I'll give 850 a go! I'm guessing zero stability issues?
Runs fine had it like this for couple of months.
After a lot of tinkering I didnt even bother doing the - curve at the start. Didnt make any difference.
I can do 825mv @ 1890mhz too.
I was going to list my 3D Mark scores which also shows avg Mhz but just noticed all my 2021 results have been deleted !
Yeah I said that when I got the 3060Ti, then they changed the rules, so now I'm stuck lol
even if you overpaid for a 3080 retail let's say 1k you could probably sell your 60ti for 8~900 so would still work out just under msrp for a 3080.Same here.
3060 Ti was a paltry upgrade from a 5700 XT. But at least it gave me RT and DLSS. Just gutted it effectively rules me out of getting a 3080 at any vaguely reasonable price (unless OCUK do a deal, but given how many backorders they have for 3080s, that seems highly unlikely).
warning about the SAM Bios, applied it to my 3080 on a Tomahawk x570 (1.50 Bios) but didn't reboot it until the next day (when I'd forgotten I'd done it) and BIOS wouldn't post or enable the screens, with one long and two short error beeps. Happening to a lot of people, in my case clearing the BIOS worked to post. You need to disable CSM (so it's pure UEFI) and also enable 'above 4GB decoding', then it works on Zen2 for me (3950x). We'll the driver says so, haven't tried a game yet.
Strange that it won't post otherwise, they should have caught this.
) and on my motherboard when I enabled Resize BAR - above 4gb decoding became enabled automatically so it might be down to the M/B manufacturer not following the correct standard so this part of the activation its not really down to AMD or Nvidia really.3080Ti drop according to discord, anyone would think its April the 1st...
