- 27 Aug 2003
- West Midlands
Nope but I'll give them a go
Cheers dude.
Cheers dude.
Cheers dude.
I should check as she was looking like an extra from the walking dead when I left for work this morning.But she's breathing, right?
Spoke to Sue this evening and she did say for big jobs its 2-3 weeks off right now, hoping mine is a spot job they can fit inbetween other booked work.
Is that foam stuff any good compared to just using normal shampoo? I've always thought of it as a bit gimmicky.
Most on the market are useless and yes a gimmick.
Bilthamber (when used strong) and magifoam however actually shift dirt really well. I prefer the magifoam for the thickness stops it drying out in the sun. And the results above speak for themself tbh![]()
Magifoam is great as a reset but will destroy any ceramic coatings. Hopefully you re-coated/protected the car after that.
Didn’t seem to on my R8 which had Geyon ceramic coating.Magifoam is great as a reset but will destroy any ceramic coatings. Hopefully you re-coated/protected the car after that.
Dint covers tend to scratch though? Liking the contrast between the car and drive. Just fir a laugh have you tried fitting it in the garageDo you plan for a cover or anything? I have an outdoor cover for my 4C just because I hate how grimy it gets. Not 2 hours after washing and it’s filthy again from dust or rain, season dependant!
Driveway looks awesome, I’m so hyped for the day I afford a garage lol.
