Finally got round to proper 3dmark06 run on the XP Machine.
C2Q Q6600 (Stock speeds)
2GB RAM (667mhz)
3870x2 (Stock)
Score 12592
- ATI Radeon HD 4890 video card benchmark result - Intel Core 2 Quad Processor Q6600, (3dmark.com)Wow. How is it so close? Your cpu was @ 3.3 too? This one is stock!That's not bad at all, that!
found my old Q6600 box from back in the day as a comparison- ATI Radeon HD 4890 video card benchmark result - Intel Core 2 Quad Processor Q6600, (3dmark.com)
It FLEW! at the time, those 4890 cards were unbelievable. A bit of me still wants a crossfire setup of them again
Got the Sonic 3 soundtrack recorded off of the SW60XG today.
Going to do Sonic and knuckles next.
Cheers man!Haha! Nicely done
Also subbed!
Cheers man!
I'm working on a video where I will refurb the 3870x2 (its in really poor condition and has had parts of its backplate actually sawn off!)
Filmed a little practice just unscrewing it all to see how the quality and camera angles would look. Got the approval of my brother (He owns a video/music studio)![]()
I would love to say I have some clever/professional method but it’s literally just a shielded aux cable into my windows 10 PC. Then use the built in “voice recorder” using the line in instead of mic. Then convert those to WAV. Then use FL studio which has a denoiser built in.Really awesome dude. How you capturing your audio? What program and equipment you using?
I got so many cards I'd love to capture audio from.
Interesting. Does this act as your CD drive with mounted ISOs / Cue / other images and does it cause problems with audio or stuttering in games?Added a 16gb CF card to act as drive D:, i didnt want to use a riser slot, so unmounted it and hot glued it to some adjusted plastic mobo mounts
added the gigabit NIC, but since read win98 is rubbish at transfer speeds, ive kept it in anyway has the netgear install adds a status icon in the taskbar. I disabled the on board lan in the bios, but its still showing in device manager.
I’ve tried mounting cd images on usb2 and hdd and analogue audio creates massive lag in some games.
A device that acted like a fake cd drive with an audio to soundcard connector may work.
A good example is Forsaken, it stutters ever 2 seconds with mounted images and cd audio on. Playing off the cd is fine. I guess it’s a Daemon tools analogue audio problem
