Hi, just a quick question. Will my Ryzen 5 3600X bottleneck the rx 6700 xt gpu? Mainly gaming and video editing but not a lot. Thanks
It depends what you are doing, in could do yes, but probably not in a significant way, I don't know anything about video editing but with gaming, if you are playing a game like Shadow of the Tomb Raider or Cyberpunk 2077, then it's absolutely possible. However I'm not sure that people fully appreciate what is meant by bottleneck oftentimes, it's a simple concept but is really quite involved with the factors that can play into this and how it could manifest and under what conditions etc. For example, on of the areas you might see some level of bottlenecking with a 6 core CPU is with a game that can actually utilise all the cores and when the system is doing something else aswell, it may not even be as straightforward as you could get a higher frame rate with an 8 core or more, infact it's very possibly not the case it might be that you could get better frame times, i.e. a smoother and more consistent experience. In short, I think you'll be fine, if you have any issues with the performance you are getting then in might be time to look into why but a 3600X is an appropriate CPU to pair with a 6700XT in my opinion it's not an imbalanced configuration.Hi, just a quick question. Will my Ryzen 5 3600X bottleneck the rx 6700 xt gpu? Mainly gaming and video editing but not a lot. Thanks
Who's running their card on a b450 board. Any issues?
nope stable and running like a charm.Who's running their card on a b450 board. Any issues?
None on mine
Thanks a lot folks. On the radeon software it was saying that my old gpu rx 5500 xt was underperforming with R5 3600x. I never noticed any stutter in any of the games. I was looking to replace it with 3900X, but comparing the specs it was just a little bit better. I think I will leave it for now.It depends what you are doing, in could do yes, but probably not in a significant way, I don't know anything about video editing but with gaming, if you are playing a game like Shadow of the Tomb Raider or Cyberpunk 2077, then it's absolutely possible. However I'm not sure that people fully appreciate what is meant by bottleneck oftentimes, it's a simple concept but is really quite involved with the factors that can play into this and how it could manifest and under what conditions etc. For example, on of the areas you might see some level of bottlenecking with a 6 core CPU is with a game that can actually utilise all the cores and when the system is doing something else aswell, it may not even be as straightforward as you could get a higher frame rate with an 8 core or more, infact it's very possibly not the case it might be that you could get better frame times, i.e. a smoother and more consistent experience. In short, I think you'll be fine, if you have any issues with the performance you are getting then in might be time to look into why but a 3600X is an appropriate CPU to pair with a 6700XT in my opinion it's not an imbalanced configuration.
Think I may have been unfairly blaming the b450 board. Just tried the card back in my x570 system and I now have the exact same symptoms. Looks like another dead 6700xtnope stable and running like a charm.
Is this the Powercolor Fighter ?Think I may have been unfairly blaming the b450 board. Just tried the card back in my x570 system and I now have the exact same symptoms. Looks like another dead 6700xt![]()
It looks like the fighter just upset something about the display port on my monitor. I powered it off for a while now I'm getting a signal from my other gpus/system. I've requested an RMA![]()
Yes. I blamed the b450 board initially but it won't boot in anything now. Can't seem to get a display out of any board that's had that card in it now. Hope it's not killed my boards![]()
