Has anyone here ever tried messing with in-hotend material mixing before?
What do you mean?
I can use the filament sensor to change colors.
What do you mean?
Yeah E3D Cyclops sort of thing. I was wondering bcs some of my prints would do far better if bits were more compliant by mixing in TPU or the sort.I think they are referring to a mixing hotend such as the E3D Cyclops, I've got one but other than a couple of dual colour prints not got any experience using it.
Finished converting one of my printers to 2.85/3.00mm filament, so here's a 3DBenchy.
Nice....looks like a benchy! Did it print significantly faster? That's the idea, isn't it?
	Ah, I see. I'd incorrectly presumed a direct link between filament size and nozzle size. So if you stuck a SuperVolcano (or something similar) in as your hotend to provide faster melting you could then get faster print time by using a wider nozzle but at the expense of fine detail.
Not really 3D printing but some parts of it are 3D printed. I suppose I could mount a big-ass extruder to it. It does use a Duet board though so I guess there's some commonality.
My PrintNC CNC router:
It's mostly a ThreeDesign PrintNC but with a number of modifications by myself. For starters the PrintNC usually runs LinuxCNC but I wanted to use a Duet because at the end of the day it's only a router. Not like it's a 5-axis mill.
Oh, and it's water-cooled. Yes, using off-the-shelf PC WC parts.
Partially, yes. The pendant is off-the-shelf but I had to build a setup to communicate with the Duet. This required an Arduino. The display on the pendant is mine, yes.
Hey all, I know @deuse has a CR-6SE but does anyone else?
I wonder if @deuse and those that do can post a picture of the control board wiring both the stock board and a BTT CR-6SE board if that's what you have.
Many thanks,
James.
EDIT
Specifically how the Z endstop/probe etc is wired and how many wires it has.
https://damsteen.nl/blog/2020/11/25/how-to-btt-skr-cr6-installation
The first BTT V1 board had problems.
There is a better version, but BTT never change it the version number.
Best firmware for it is this one https://github.com/CR6Community/Marlin/releases/tag/v2.0.7.3-cr6-community-release-6
Hope that helps
