Cheers for the heads-up mate, any chance you could send me the suggested groups?
Cheers
Its posted in this thread pretty much every week and multiple times after each drop. Have a look through the thread and you’ll find it.
Cheers
Try Telegram also, google FE PartAlert, for some reason it doesn`t show up when you search in the app, and use that, I found it more reliable than Discord recently.Cheers for the heads-up mate, any chance you could send me the suggested groups?
Cheers
Its posted in this thread pretty much every week and multiple times after each drop. Have a look through the thread and you’ll find it.![]()
CheersTry Telegram also, google FE PartAlert, for some reason it doesn`t show up when you search in the app, and use that, I found it more reliable than Discord recently.
345 pages, ok, great
Is it normal the 3080FE runs at 30% RPM (aprox 1000rpm) all the time at idle in windows?
Just use amazon pay guys, no need to enter card details, not sure why you want to manually enter card details and slow down your checkout.
Do you have any monitoring software installed such as MSI Afterburner?My gpu is not dropping back to 0% after 15 minutes so far if i play a game. Its still at 1000rpm and temperature is 41oC
Is it loud or something? I'm not sure what the fuss is about.
What the hell, surely no one would buy that? Sometimes sellers (including on auction websites) sell items at extremely high prices, as they think no one will bid for them/ buy them (then set a real price later), could be what's happening here.Overpricers are definitely taking the crown of scalping
£2700. Is that correct?
£1400 is the founders price. What makes this £1300 more expensive exactly?
