IT WORKED!!!!!!![]()
Well done!
IT WORKED!!!!!!
Hours upon hours of trying to fix these damn BSOD's, and a very sleepless night where I could've lost everything ( *** YOU MICROSOFT ). It turns out the reason why it's BSOD'ing is because Windows 20H2 updates the Intel Management Engine interface automatically which doesn't support certain Z97 chipset motherboard Bios's. The MSI and some EVGA boards. The only way to fix it, is to flash to the latest BIOS and then re do the update! Basically the Interface is talking to the wrong code of the system hence BSOD every time when Windows thinks it knows best! I would never have known this if I hadn't typed the name of my motherboard and this update version!
To be fair there are a million and one things like this which could trip up updates - sure many of them individually are simple to test but that is a lot of testing collectively.
(It doesn't help MS have massive reduced down their internal testing and only listen to what they want to hear from external testers/"insiders").
Which is why you don't use an updates approach like they are using in Windows 10 it is just idiotic.
Security updates need to be quicker and easier to apply and entirely separated. Hardware updates should never be pushed through automatically but notified if there are critical security, performance or compatibility issues, feature updates should be left to the end user's leisure. Anything else is utterly pants on head.
My best memories in trust with Microsoft were from the XP days. 2001 to 2007 when Vista hit. I rarely ever remember worrying about updates from Microsoft borking things. There was a decline with Vista testing then Microsoft ramped it up when 7 launched. 7 was as solid mostly as XP from their testing and launch of updates.
Are you expecting 21H1?Here we go, image complete!![]()
Are you expecting 21H1?![]()
He does an image every time there's a 1kb update.
Reports of the latest Patch Tuesday security update (KB5001330) causing all sorts of issues, BSOD, performance problems etc... etc..., luckily, im having no issues.
