Poll: *** The official 24" M1 iMac thread (it has seven colours and everything!) ***
Are you buying a 24" M1 iMac?
  • Total voters
    91
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Thought we should have a thread for this.
Who is buying one on the 30th?
Not buying, but it looks perfect for the market at which I believe it is aimed. I bet even my Mam would have one in her house and she doesn't get on at all well with technology.
For me this is a perfect machine for my work which is web browser, office suite and meetings. I also know from experience that the M1 with 16GB RAM can handle Adobe Lightroom without issues.
External SSD .Can anyone please recommend a suitable one i can use with a new mac when they are released.1TB should be fine. overclockers do quite a few I believe so maybe something from the store?
thanks
If just using the new imac for Apple photos editing,am I correct in thinking the base machine with 8gig ram is enough, and using an external SSD for photos Library which is sitting at around 300gig at the moment? thanks
Personally, pay the few hundred extra and go for 16GB. The 8GB M1 Air I had would heavily lean on swap when having a number of apps open, which resulted in those apps having this popping effect as they are quickly pulled back from swap.
@ChrisBuzz - going off your question about photo editing, I'd suggest pretty much any external that fits the budget will be sufficient. :) Mechanical mobile drives will be slower than their desktop counterparts but are much smaller. Of course, if you were after backing the data up, the cheapest option could be using two drives or investing in one that can do this for you (MyBook Duo).
I could certainly see myself tempted away from my current setup to one of these, especially if the need to hot desk and work on the fly comes to an end.
The problem is there aren't any monitors you can buy that are comparable to this.
thats what stopped me buying the Mini M1 when it was released,i dont know what monitor would compare but it was just the stress of looking and trying to find one that was a near as it could be,so i decided wait for the new imac. Did Apple used to or still do sell seperate monitor that is similar?
thankyou.I have made my mind up to get an SSD. what is the reason the mechanical drives are smaller,I thought they would be bigger because of the mechanics or is it that the SSD has to have a bigger enclosure?
Here is a post I made on the screen in the other thread.
I'm pleased with the screen on the new iMac, I was worried that at 24" they would go with 4K which isn't up to the usual Apple levels. The 24" LG UltraFine 4K has always been a little lacking and effectively only displays 1920x1080 when using retina pixel doubling.
Here's how the new screen measures up in terms of PPI and effective resolution when using pixel doubling.
21.5 Retina iMac
Native: 4096 x 2304
Retina: 2,048 x 1152
PPI: 218.58 pixels per in
24" M1 iMac
Native: 4480 x 2520
Retina: 2,240 x 1,260
PPI: 218.73 pixels per in
24" LG UltraFine
Native: 3840 x 2160
Retina: 1920 x 1,080
PPI: 185.9 pixels per in
27" 5K iMac
Native: 5120 x 2880
Retina: 2560 x 1440
PPI: 217.57 pixels per in
2,240 x 1,260 on the 24" (23.5) will be a very nice amount of space, very usable. It will look extra crispy with the proper amount of PPI.
It's more a thing of portable mechanical drives using the 2.5" disks rather than the 3.5" disks like in desktop storage. Makes them smaller, lighter and ultimately more portable. SSD's are of course much quicker and can be smaller again. I have a My Passport SSD which is half the size again and very fast.
yes that sounds more like I want :)
I will need to buy some sort of USB hub as im going for the base model with just the 2 thunderbolt option. does that need to be a different connector for the thunderbolt I guess,plenty around?i use wifi so dont need ethernet. or touch keyboard, but like our friend suggested will look at getting the xtra ram
Using still my mid 2011 27 Imac but my canon CR2 raw files turn magenta when taken into Apple photos,so im converting in canon DPP first.High Sierra is the culprit I think, had apple support on the phone from County Cork the distribution manager Anthony for 11/2 hours the first time and 1 hour the second, they are now wanting to go through me putting catalina from an externa drive to see if that sorts the problem, im amazed at the support for a 10 year old imac.
