- 28 Nov 2018
- Monstrocity
its a step in the right direction for monitoring, good first effort i would say
I agree, baby steps to make sure things work!
Yes.
Nope.Can you confirm if there is driver level optimisation for AMD encoding with OBS with this driver?
Nope.
OBS is a third party app, I'm not sure what driver optimisations could be done since it uses the AMD Advanced Media Framework SDK AFAIK.Any ideas if at AMD this is something thats being looked into?
Nvidia, Intel and AMD products can currently only decode, not encode AV1.cant amd use that avc1 thing to encode with on hardware using obs might be better than whatever amds ancient codec thing does still.
One of the new features is a new on screen overlay graph. I really like it.
You can customize the size, metrics, colours, transparency, position etc.
wheres the option to move it? im blind and cant find it - edit never mind found it, seems theres 2 locations for the metrics and i was in the wrong one. likely needs some clean-up in that respect but looks very good.
Not on mine, 6700xt with latest drivers.
No issues here with the 21.4.1 driver and Valhalla, just ran a few benchmarks no crashes.This new driver is really bad for Assassin's Creed Valhalla, keep crashing to the desktop, so annoying
I've been getting crashes on Valhalla on all the drivers released this year so I don't think it's specific to the latest ones although I suppose it could have made it worse, hopefully not! My inclination is that it's an issue with the game although it does reset my driver settings following a crash. There seems to be certain areas in the game that are sensitive to crashing. Following a crash if I immediately go back to the same spot, it often crashes again. I try to avoid that area after a crash now or don't look in the same direction! I can have 4-5 crashes in one night followed by 20 hours of stable game play.This new driver is really bad for Assassin's Creed Valhalla, keep crashing to the desktop, so annoying
Does that happen with everything at stock? Because the behaviour you describe happens if the driver detects instability in the system, as well as just a typical driver crash/bug.I've been getting crashes on Valhalla on all the drivers released this year so I don't think it's specific to the latest ones although I suppose it could have made it worse, hopefully not! My inclination is that it's an issue with the game although it does reset my driver settings following a crash. There seems to be certain areas in the game that are sensitive to crashing. Following a crash if I immediately go back to the same spot, it often crashes again. I try to avoid that area after a crash now or don't look in the same direction! I can have 4-5 crashes in one night followed by 20 hours of stable game play.
