- 10 Nov 2012
- Down the road from Diddly Squat Farm
Got mine from Here
Yeah that ones now outdated if your on the latest agesa. Newest one is ctr. 2.1 rc5 but that’s beta and only available if you subscribe to the creators Patreon page. The new version is a step up and a lot more stable. Also features px single core boost.Got mine from Here
Doh, I dont patreonYeah that ones now outdated if your on the latest agesa. Newest one is ctr. 2.1 rc5 but that’s beta and only available if you subscribe to the creators Patreon page. The new version is a step up and a lot more stable. Also features px single core boost.
That seems pretty low... what cooling do you have and what are temps like?![]()
And there was me thinking it might be a silver class chip. Oh well, I'm still happy with it.
What does HWINFO say your max temps get to during a run of Cinebench R23?I'm using a Noctua DH-15.
I completely misread your CPU as a 5900x instead of a 3900x... sorry about that. However, I think if you are hitting 92c then you are still being thermally limited from achieving higher clocks. Try setting a -20 negative offset on all cores (assuming you can do that on Zen2).
CCX COEFFICIENTS
CCX# 1 0 CPPC 185
CCX# 2 0 CPPC 168
CCX# 3 0 CPPC 152
CCX# 4 0 CPPC 136
DIAGNOSTIC RESULTS
AMD Ryzen 9 3950X 16-Core Processor
CPU VID: 1213
CPU TEL: 1169
Max temperature: 40°
Energy efficient: 3.46
Your CPU is BRONZE SAMPLE
Recomended CCX delta: 25
Theoretical maximum CCX delta: 50
Recomended values for overclocking (P1 profile):
Reference voltage: 1225 mV
Reference frequency: 4050 MHz
Recomended values for overclocking (P2 profile):
Reference voltage: 1325 mV
Reference frequency: 4200 MHz
Recomended values for undervolting:
Reference voltage: 1150 mV
Reference frequency: 3900 MHz
Penalties for the final profile: level 1
10:34:28: CCX1 (185): 4075 MHz, 1231 mV OC+
10:34:28: CCX2 (168): 4075 MHz, 1231 mV OC+
10:34:28: CCX3 (152): 4050 MHz, 1231 mV OC=
10:34:28: CCX4 (136): 4075 MHz, 1231 mV OC=
Cinebench R20 started
Cinebench R20 finished with result: 9478
Voltage: 1.231 V PPT: 152.7 W Temperature: 66.4°
11:41:05: CCX1 (185): 4300 MHz, 1331 mV OC=
11:41:05: CCX2 (168): 4325 MHz, 1331 mV OC=
11:41:05: CCX3 (152): 4225 MHz, 1331 mV OC=
11:41:05: CCX4 (136): 4250 MHz, 1331 mV OC=
Cinebench R20 finished with result: 9977
Voltage: 1.331 V PPT: 188.8 W Temperature: 77.6°
12:40:07: CCX1 (185): 4275 MHz, 1336 mV OC+
12:40:07: CCX2 (168): 4275 MHz, 1336 mV OC+
12:40:07: CCX3 (152): 4200 MHz, 1336 mV OC=
12:40:07: CCX4 (136): 4250 MHz, 1336 mV OC=
Cinebench R20 finished with result: 9879
Voltage: 1.338 V PPT: 190.8 W Temperature: 77.8°
