ClockTuner 2.0 for Ryzen... do YOU have a Golden Sample? Post your results here. :)
1 Oct 2004
Newcastle upon Tyne
DIAGNOSTIC RESULTS
AMD Ryzen 7 5800X 8-Core Processor
CPU VID: 1061
CPU TEL: 1035
Max temperature: 58.6°
Energy efficient: 4.23
Your CPU is GOLDEN SAMPLE
Recomended values for overclocking (P1 profile):
Reference voltage: 1250 mV
Reference frequency: 4650 MHz
Recomended values for overclocking (P2 profile):
Reference voltage: 1325 mV
Reference frequency: 4750 MHz
Recomended values for undervolting:
Reference voltage: 1125 mV
Reference frequency: 4400 MHz
This on with a Dark Rock Pro 4 air cooler
Stu
Stu
19 Oct 2002
Wirral
Yeah that ones now outdated if your on the latest agesa. Newest one is ctr. 2.1 rc5 but that’s beta and only available if you subscribe to the creators Patreon page. The new version is a step up and a lot more stable. Also features px single core boost.
Might explain why it won't work for me (I'm on latest BIOS for X570 Tomahawk).
Caporegime
OP
8 Sep 2005
Utopia
I completely misread your CPU as a 5900x instead of a 3900x... sorry about that. However, I think if you are hitting 92c then you are still being thermally limited from achieving higher clocks. Try setting a -20 negative offset on all cores (assuming you can do that on Zen2).
30 Dec 2011
Belfast
I ran the diagnostics on my 5900X just to see what it reported, said it was a platinum sample. I just run mine at stock as days of tinkering with curve optimisers for a few meagre percent of performance is worthless to me.
3 Mar 2015
Wokingham
I have a 'Silver' 5900x (air-cooled). See my stats on the Ryzen 9 excel sheet the tool provides under the user ID 'henry'.
I found that the tool struggled with errors with my heavily OC'd RAM, but was happier when I set that back to XMP (3600).
I also found CTR was happy to set my CPU profiles to 4425 MHz on both CCM's (or around that level) for high-CPU use (83%+). But then, when I thrashed the CPU under Nicehash calculations (which pushes it WAY harder than Prime 95, in my view) it hit 90 degress and throttled very quickly indeed! This tells me that the 'Tune' function (in the 2.0 R5 release) isn't making the CPU work hard enough to get the highest heat in tests It's ok for gaming Im sure, but not for top-end carnage :)
13 May 2010
Using a Noctua NH-D15s chromax.black on my 3950x, MSI MEG x570 UNIFY motherboard. Mine is only Bronze unfortunately. Although CCX3 has a higher CPPC than CCX4, the latter overclocks a bit better.
Code:
CCX COEFFICIENTS
CCX# 1  0  CPPC 185
CCX# 2  0  CPPC 168
CCX# 3  0  CPPC 152
CCX# 4  0  CPPC 136
DIAGNOSTIC RESULTS
AMD Ryzen 9 3950X 16-Core Processor
CPU VID: 1213
CPU TEL: 1169
Max temperature: 40°
Energy efficient: 3.46
Your CPU is BRONZE SAMPLE
Recomended CCX delta: 25
Theoretical maximum CCX delta: 50
Reference voltage: 1225 mV
Reference frequency: 4050 MHz
Reference frequency: 4200 MHz
Reference voltage: 1150 mV
Reference frequency: 3900 MHz
These are the results from testing at a few different frequencies/voltages.
Code:
Penalties for the final profile: level 1
10:34:28: CCX1 (185): 4075 MHz, 1231 mV  OC+
10:34:28: CCX2 (168): 4075 MHz, 1231 mV  OC+
10:34:28: CCX3 (152): 4050 MHz, 1231 mV  OC=
10:34:28: CCX4 (136): 4075 MHz, 1231 mV  OC=
Cinebench R20 started
Cinebench R20 finished with result: 9478
Voltage: 1.231 V  PPT: 152.7 W  Temperature: 66.4°
11:41:05: CCX1 (185): 4300 MHz, 1331 mV  OC=
11:41:05: CCX2 (168): 4325 MHz, 1331 mV  OC=
11:41:05: CCX3 (152): 4225 MHz, 1331 mV  OC=
11:41:05: CCX4 (136): 4250 MHz, 1331 mV  OC=
Cinebench R20 finished with result: 9977
Voltage: 1.331 V  PPT: 188.8 W  Temperature: 77.6°
12:40:07: CCX1 (185): 4275 MHz, 1336 mV  OC+
12:40:07: CCX2 (168): 4275 MHz, 1336 mV  OC+
12:40:07: CCX3 (152): 4200 MHz, 1336 mV  OC=
12:40:07: CCX4 (136): 4250 MHz, 1336 mV  OC=
Cinebench R20 finished with result: 9879
Voltage: 1.338 V  PPT: 190.8 W  Temperature: 77.8°
Stu
Stu
19 Oct 2002
Wirral
New version out now, which works for me... golden sample. 5900x with Arctic Liquid Freezer II 280.
DIAGNOSTIC RESULTS
AMD Ryzen 9 5900X 12-Core Processor
CPU VID: 1099
CPU TEL: 1048
Max temperature: 57.36°
Energy efficient: 4.17
Reference voltage: 1175 mV
Reference frequency: 4425 MHz
Reference voltage: 1275 mV
Reference frequency: 4575 MHz
Reference voltage: 1000 mV
Reference frequency: 4075 MHz
However, the fan curve on ALF (Has anyone called it that before? New trend?) does not ramp up until 60C, so I might get a better result if I increase fans.
10 Jan 2003
staines
DIAGNOSTIC RESULTS
CPU VID: 1087
CPU TEL: 1051
Max temperature: 75.96°
Energy efficient: 4.16
Recomended CCX delta: 50
Theoretical maximum CCX delta: 75
Reference frequency: 4450 MHz
Reference frequency: 4600 MHz
Reference frequency: 4100 MHz
I got the liquid freezer II 360 stu... and my temps :(
