https://affinity.serif.com/en-us/
50% off all the Affinity programs (Photo, Designer, Publisher)
£23.99 each for lifetime updates
50% off brushes and stuff too - https://affinity.serif.com/en-us/store/
Nice. Is the publisher quite easy to use ?
Still expensive as a one off but better than Adobe subscription.50% off Capture One at the moment using code MAY-SAVE-50![]()
I like CO a lot and it’s been a revelation since I started shooting Fuji but I was more than a little peeved that I hadn’t owned CO 20 for even 4 months and them 21 came out. I initially got over it but I’ve since purchase an X-S10 which 20 doesn’t support![]()
Since 2014 it seems to be annual. As I got CO20 for around £45 IIRC I got over the fact that CO21 came out not long after but it's ridiculous that they can't add X-S10 support to CO20. The files are exactly the same with same sensor/processor at X-T30 and X-T3 so there's no technical reason for them not adding support. FYI I use an EXIF editor and literally just need to change X-S10 to X-T30 and it imports but that's not a solution.What's their release cycle like? I'm on the fence since I got the X-T4, currently using the 'free' version but it's fairly limited and I don't like Lightroom that much.
I just don't want to buy 21 then have 22 come out in say, 6 months time....
It does yes. It's probably the best I've used besides Lightroom.Does CO have a library function like Lightroom?
Topped up my LR for a year.
