 - 30 Mar 2016
 - East Lothian
Lucky if I can 20 minutes now without it crashing.  Doesn't like me using my eagle in particular.  It could be coincidence but it does seem worse since the latest patch.
So I get to pick between AC Valhalla and that Fenyx game for purchasing a new Samsung SSD. For folks that have played both, which do I go for?
I like them both, I would find it hard to choose if I could only have one.
If I really had to decide, seeing as I have other AC games, I would go for Fenyx.
Yeah odyssey had too many weapons and armour while Valhalla not enough and the costs to rank up the gear made it differcult to swap between different play styles or try experiment and try something new.I felt the same regarding feeling OP @smogsy as soon as your able to kill the zealots and get beyond the second item armour set it becomes hardly a challenge. I think its about level 70 or maybe 50 hours in something like that. I did try to kill the big wolf in asgard too early and that was my most difficult battle by far.
I did download and play Odyssey but this was listening also to people that have not played Valhalla yet rate it. So after about 10 hours I wasnt impressed to be honest - it has equally enough bad points and if anything far too many weapons. Seems like ubisoft cant balance any game at this rate.
Once I got the dual daggers with life drain crit it essentially became easy to kill anything even bosses that were 150 levels higher.
Dual wielding the kopis + yngling seax with curative perfection runes and a speed/crit build.After landing in England the first obscure weapon I picked up was the Flail. I used this for ages was very nice with a shield. Once you start using the runes and actually stack buffs its game over if you want a challenge. The biggest OP weapons by far are if I duel wield spears. Lovely combat but you turn into God so experimented with other weapons after realising this.
Ed - what is life drain crit?
Ed2- I also forgot I need to get the roman artifacts done to get that shield.. doh
