** Resident Evil Village Thread **
  • Thread starter Thread starter TNA
  • Start date Start date
I forgot I had a magnum but will use it this time around making sure I have plenty of ammo with everything else being fully upgraded.
The upgrades were strange one, I had upgraded all the weps where I could but some didn't feel like it changed them that much. My shotgun was maxed as was pistol
Had trouble with the last boss as I only seem to be tickling it so had to change the difficulty, but perhaps I did not have the best weapons to hand.
On my 'Village of Shadows' playthrough, the best weapon against her seemed to be an upgraded assault rifle - I had the fully upgraded AutoMag but she moves around so much that 'spray and pray' seemed to be the best tactic :D
This is a very dark game obviously, is there a monitor this looks decent on (i.e not washed out / grey) or given its not much of an improvement visually over the xsx / ps5 is it better to just play it on those on a big oled TV?
In the room/dungeon outside the special chamber where you get the Azure ring I am missing a collectable but cannot find it. Is there a jewel in this area?
The Hooligan challenge, I have broken every window but it is showing 'Not Completed', does this only register on completion of the playthrough.?
No it comes up right away but it has to be done in 1 play-through
Then it must be glitched as I checked all windows were done twice. Oddly I am sure I did it the first playthough also.
Head back through the kitchen into the dungeons, there's a locked door.
I have opened the locked door and got the treasure, this is the dungeon outside that door which is still showing red.
Bit academic now as I have moved on since posting.
looks amazing on my pg35vq
Not sure I like that you cannot get back to some areas as I missed an outhouse and it is in the Moreau reservoir area and the lift no longer works so the challenge 'When you Gotta Go cannot be completed.
Also Hooligan which I completed did not register and I am absolutely sure I got all windows.
Anyone running this at 4K 60 FPS on a 3080 ? what settings you using or does anyone know where i can look for recommended settings ?
