- 27 Jan 2003
- Chesterfield, UK
It’s about 20 to 23 ish for a 5900X depending on settings.
a familiar tale
My 5800x / MSI x570 pro-a combination is (was) the same. After countless hours trying and replacing things, I RMA'ed the chip. It's with Overclockers now so I don't know how it'll all end.
The only thing (and I tried every combination of things I could, apart from a new mobo) that kind of worked for me was MSI's latest beta bios with AGESA 1.2.0.2. Running this severely limited the chip's boost frequencies (knocked about 200MHz off single core boost and about 400MHz off all core boost) but it stopped the crashing at least
Are you keeping your original graphics cardJust ordered a new PC with 5950x, my first PC in a decade.
My last system I had, I was on a Q6600.![]()
kinda wished I stuck with the 6700k and its not like the new parts are cheap , guess if I cant find the solution I can RMA the chip and at least will confirm if the chips faulty or not and move onto the next part I feel its the CPU / Board or Bios issue and maybe fined with update ?
Dialback on the curve optimise on the core that gave the whea error. In your case ap4, which is core 3, 0/1 2/3 4/5 etc
So don't go as negative, run ryzen master, it'll give you the breakdown of your best cores, these will not take as much negative core optimiser as poorer core.
I might look into it sometime in the future at the moment just will be happy with stable system and the clocks dont seem to bad either but would love to try for 5ghz single boost I know its doesnt make any difference but still
I'm keeping the 3090 strix that comes with it.Are you keeping your original graphics card![]()
Upgraded from 6700k to 5800X. Definitely feels faster.Will i notice a good improvment in framerates?
Anyone upgraded their gaming pc from a 6700k to a 5900x, im thinking of getting a ryzen setup and with the money ill save from not upgrading my gpu as im not willing to pay silly money for it, the money i do save ill get a better cpu. Will i notice a good improvment in framerates?
Improvement in framerates? Maybe ONLY where previous CPU was pegged and GPU wasn't. Off top of my head, E-sportsy games? Newer games that legitimately load 8 cores?
Think I'll wait then.
6700K is capable still. You may wait for DDR5 systems next year. Both Alder Lake and Zen 4 are promising impressive IPC gains.
I went from a 6700k to a 5900x a few months ago and could tell the difference FPS are a lot more stable I don’t sUffer the dips anymore pretty mUchsticks at 165fps now when gaming without any problemsAnyone upgraded their gaming pc from a 6700k to a 5900x, im thinking of getting a ryzen setup and with the money ill save from not upgrading my gpu as im not willing to pay silly money for it, the money i do save ill get a better cpu. Will i notice a good improvment in framerates?
