Do you really need PS4S on an executive saloon? PS4 are brilliant, as are F1 Assy 5s now that Goodyear have sorted out their wear rate.Check they also do them in your front size. For me they didn't so I had to go with PS4.
Fair enough. PS4S are perfect for that occasional track use your 530d seesThere isn't generally much overlap in size, for the odd size both are available but generally your tyre size will dictate whether you get PS4 or PS4S.
I always buy the best tyres available for my wheel size, so yes I'd have fitted 4S had they been available for my front wheels.
Fair enough. PS4S are perfect for that occasional track use your 530d sees![]()
Fox has a 530d. Look, I’m all for the best rubber money can buy (I put PSS on my 2.0 TDI A6 6 years ago), but I was just expressing surprise that PS4S are worth it over the PS4 for a “normal” car.I can overwhelm them with the throttle in a straight line on demand at any speed below about 120mph on anything other than a warm sunny dry day on the back of my executive saloon.
Tempted to look at Pirelli Corsa next time around but then I really would need to switch wheels in winter if I wanted to get anywhere reliably...
Fox has a 530d
I don’t see the issue, PS4S is what will be going on my 440i when it’s due in a few months, as with Fox, why would you not just fit the best tyres you can?
FWIW, I can (and do) break traction in even mildly cool or damp conditions, so am more than happy to put on the best tyre for the conditions, likely even including winter tyres come November.
Wow did I touch a nerve? I buy the best I can too. Just having a chat on a forum. Blimey. I thought you were nice DRZNot an executive saloon though so the tyre police dgaf.
Aye fair enough, I totally agree. I just forgot that the PS4S is the PSS replacement and the PS4 is the PS3 replacement, but significantly improved.At the risk of banging an old drum, I did discuss with my (none car enthusiast) friend at work he asked why does he need better tyres on a polo than just the cheapest as he's never needed anything better. I tried to explain its more of an just incase, but he was having none of it. I am getting some ps4s's on the back of my e92 on Saturday. I've got SS on there ATM, but somethings when wet, and quite often when setting off it does wheelspin.
As Fox says, not available in all sizes. Is the F1A5 available in that size?I need new tyres on the back of my 730d, 275/35 R20, I can only find the PS4 in runflat, not PS4S, is that right?
P Zero's on at the moment and I'm not a big fan... can quite happily break traction.
Wow did I touch a nerve? I buy the best I can too. Just having a chat on a forum. Blimey. I thought you were nice DRZ![]()
Would you like a hug?
ClearlyNo nerves, just funWould you like a hug?
All over the country Nissan Leaf owners just retreatedIt's not a BMW M5 but it does have 260bhp, 580nm, is capable of 155mph and can do 0-60 in 5.8 seconds.
Did you get your car sorted? I thought you had a major engine problem?At the risk of banging an old drum, I did discuss with my (none car enthusiast) friend at work he asked why does he need better tyres on a polo than just the cheapest as he's never needed anything better. I tried to explain its more of an just incase, but he was having none of it. I am getting some ps4s's on the back of my e92 on Saturday. I've got SS on there ATM, but somethings when wet, and quite often when setting off it does wheelspin.
Yes cheers, bmw replaced the engine cost me 600 quid so pretty good deal, although I am having to pay for the running in service in a couple of weeks.Did you get your car sorted? I thought you had a major engine problem?
