- 7 Feb 2014
- Lancashire
Managed to pick up one of these but still using a 1080Ti which I do not think supports DSC so am finding it a bit limited. (Still struggling to buy a 3080 FE, I'll get there one day). 0 I'm finding I can only use the 10 bit colour depth at 95hz, and can only go up to 120hz with 8 bit colour depth.
Can anyone confirm using DSC you fully utilize everything on this monitor through DP 1.4? (160hz, 10 bit colour depth and HDR)
I'm considering getting the newer model that supports HDMI 2.1 to rule out limitations when I get a newer GPU but if I can max it out with DP 1.4 I'll probably keep it.
