Anyone had issues with restricted lan port speed?
I have 1gig virgin Internet but all speed tests cap at around 210mbps.
Previous pc hit 900mbps+ with same network equipment. Only the pc is new. I've got the latest realtek drivers installed for the ethernet from the msi site.
i have the 1.5 bios and see two options:
1. that seems to indicate it is referencing SAM
2. above 4G memory/crypto currency mining
I turned #1 on and left #2 off.
Now, GPUZ reports that resizable bar = "off".
Am i doing this wrong?
Is that necessary? As part of the bios update it wipes all the settings anyway. And to perform the update, it seems to boot into a separate little tool anyway.Note: I always clear my CMOS by jumping JBAT before upgrading BIOS.
99.9% sure it doesn't matter, but just in caseIs that necessary? As part of the bios update it wipes all the settings anyway. And to perform the update, it seems to boot into a separate little tool anyway.
I guess no harm doing it.
Just tried my front USB ports (Phanteks Evolv X) for the first time... left USB-A working fine; right one is detecting external HDD and showing up in explorer, but not loading files/folders; and the USB-C port seems totally dead.
Might this be my case, or is this the X570 USB bug?
Which BIOS are you running. I only run the fan curves off the CPU at the moment on BIOS 1.6 but can't confirm what you are seeing till I get home in a couple of days. Someone here will be able to confirm I expect.Weird bug: I can see a PCIE_1 temperature in the hardware monitor section of the BIOS, but I cannot select it as a temperature source for a smart fan curve. Is this normal? (only options there are CPU, System, MOS and something else).
Bump... can anyone offer advice on my query, please?
I am not sure it does clear all settings on a BIOS update. Certainly when I updated to 1.6 it retained the RGB settings, which I am sure it wiped on some previous BIOS updates. So, who knows what else it is not clearing.Is that necessary? As part of the bios update it wipes all the settings anyway. And to perform the update, it seems to boot into a separate little tool anyway.
