@Rroff cant you just lock the GPU clock at 1000mhz or something to stop it bouncing around and the fans spinning up?.
I found something similar on my 3080 FE when Vsync was set to Fast. This was not a problem previously with the 1080 Ti.Think I've worked out why my FE is spinning up the fans intermittently with some older games - seems related to how the UI is rendered in some older games which is causing bursts of the GPU producing a lot of frames quickly even though the overall frame rate might not be overly high. If I just leave the game idle is doesn't really do it but if I'm rapidly doing stuff during gameplay dipping in and out of UI elements after awhile it will either spin up the fans periodically or for longer periods.
Not sure why my older GPUs don't do the same.
Turn the settings down if you need more FPS'WHAT DO YOU EVEN NEED NEW GPU FOR?'
Like ya know Anno 1800 runs at 30 FPS on 10900K and 1080 Ti?
Turn the settings down if you need more FPS![]()
Got the undervolt bench stable at least at .875v 1950Mhz. Any good? .9 does 2000 but the clocks fluctuate more in timespy
Yeah I'm somewhat surprised and very disappointed that AMD still won't sell to the UK.AMD is hiding behind Brexit rubbish so they don't have to sell at MSRP their cpus and gpus.. you know the white knights to save us all from Intel and Nvidia as many thought would happen on here ...
AMD have been the worst out of them all this generation of cpus and gpus.
How do people buy the FE's? I thought once they stock at launch is sold out there is no other way to get them.
I know who you mean, but they're not even listed in their graphics card section, so how do people know when they're restocked?One retailer sells FE. They drop every week or two. Its first come first served and they're gone in minutes or seconds if it's the 3080.
Is there a way to configure the alerts to only go off when it's a 3080/70 UK stock?Time it lucky or sign up to alert notifications from social media and messaging apps.
If you're going for an FE I'd actually recommend keeping all the alerts on for cards you don't want as well. From what I saw the cards often drop around the same time. If an alert for a card you don't want comes through first then you can be ready and waiting for a potential drop of a card you do want. That's how I got my 3080FE a couple of weeks ago when the 3070/3090 alerts came through first.Is there a way to configure the alerts to only go off when it's a 3080/70 UK stock?
Ok, but can I at least make it so it's UK only? If so how?If you're going for an FE I'd actually recommend keeping all the alerts on for cards you don't want as well. From what I saw the cards often drop around the same time. If an alert for a card you don't want comes through first then you can be ready and waiting for a potential drop of a card you do want. That's how I got my 3080FE a couple of weeks ago when the 3070/3090 alerts came through first.
