So after being in a queue since the beginning of October I finally received my 3080 2 weeks ago.
Since doing a clean install of windows and running everything at stock. I found the performance not being to the standard it should be.
I was getting quite low FPS in games where easily I should be getting more. Also I found games glitching and freezing up.
I investigated this via GPU-Z and found that the card at stock was using the most power as possible and was hitting max operating voltage making the performance take a huge hit and bossy clocks barely rise not even up to 1900mhz at times which is awful.
I have requested an RMA on the card to have it replaced but the only thing that looks to help is that I ran MSI Afterburner OC scanner which amended the voltage/frequency curve and now the performance seems more stable and hitting the rates I expect without the VOp message in GPU-Z however I should not have to do this to have a stable GPU.
I do have an odd issue hear and there but very minimal. Just wanted to let people know if they are having the issue to try this in the meantime.
Also is anyone else having this issue?
I think that is bad testing from ASUS on this card.
