- 24 Jun 2021
- Oxon
ah nice John he fixed your WDDM thing before I got chance to post it
ah nice John he fixed your WDDM thing before I got chance to post it![]()
W11 at final release will require Internet to install and file verification will take place. You will be unable to bypass the system requirement checks.
That will have to be disabled for enterprise and defence sector licenses, so some clever spark will adapt it for general use.
Why will it? They might make it mandatory like Chromebook logins.
Because in the defence sector there is no internet access at all on secure networks, and enterprises will want their own builds, customised with drivers, backgrounds, software, and so on.
Maybe...
Copy the reg file to the root (ie: to D:\, not D:\Sources) of your USB stick with the installation files, then boot up from it.How does one apply this at installation time? We need to rebuild the packages?
I vaguely remember you can do this with windows. But I haven't done any Windows admin for about 5 years now.
@Mel_P There is more to being Windows 11 ready than just TPM.
Continue through setup as far as you can until you see the message about not being able to install Window 11. At this message, press Shift + F10, navigate to the drive with the Windows 11 files on it.
Now find the drive your setup files and reg file is on, which is usually D:, but might be different if you have extra drives installed. Do this by typing D: and press Enter. List the files on the drive by typing DIR then pressing enter and look for the BypassTPMCheck&SecureBoot.reg file (or whatever you called it). If you don't see the file, try another drive (start with C: onwards) until you do.
With the file now found, just type in the full name of it then press Enter. Press Yes when asked if you want to merge the file, then press Okay.
This is where things might get confusing. Dismiss the message about setup not being to install Windows 11 by clicking the X on the top right of the window and confirm closure of that window. You'll return to the language selection window, which is where you were before. Now continue through setup again and hopefully that message shouldn't come up. If it does, it's probably because you have a legacy BIOS and not a UEFI BIOS like one of my older laptops.
So if you're CPU isn't on the list, and you have no TPM socket on your motherboard then you have to upgrade your PC in the next 4 years because there will be no more updates for Windows 10 by 2025.
If this is correct then you will no longer be anonymous on the net as your ID will tie you in with your history, logins, ip address e.t.c.
Fun and games.
If that works out for the better, so be it. Imagine no anonymity on the web anymore tied to ID on their computers/devices of the future, therefor a huge degree of toxic vulgar trash getting exposed for who they really are and eventually ending because of consequences.
How many times simple workaround search on YouTube. Win 11 will install on a core 2 duo
