so the 4 F-Type Connectors i can see the copper through them when i cut the cable, but i cannot see how the copper is fed through 2 F-Type coupler as its not possible to push the copper through
Ive just one ahead and attempted to connect, it appears the copper isnt supposed to go through - please correct me if im wrong, but i have another issue, the 4 F-Type Connectors, 2 are fine as the cable I bought is thicker, but when i attempted to connect the other end to the sky cable, they appear slightly thinner, and this means i cannot tighten the connector to the cable
You really don’t need to stress over this so much.
I’ll see if I can find some better videos.
Hikvision have just released some rather lovely 8MP/4K PoC ColorVu cameras with 40m soft white lights. The image quality on these is awesome. And I don’t say that lightly.
https://www.cop-eu.com/hdcvi-cameras-dvrs/cameras/DS-2CE12UF3T-E(2.8MM)
I’m expecting something similar/better from Dahua very soon.
@WJA96
These are displayed as POC, so to power them I would need to the 12v power distribution unit right?
Going through all the messages on this post again - and getting more confused.
Say I bought 5 of the above from cop. To power the cameras I would have to run a 12v power distribution unit right, otherwise how else can I get power to the cameras, of course I do not want to run additional wires to the coaxial, as you have pointed out the cable I have is a double cable anyways?
For PoC, IF you have a PoC XVR then you only need the coax cable - you wouldn’t need to use the power part of your existing RG59 shotgun cable at all.
For PoC this cable termination video is how I learned to do it. But I bought ALL the tools. I would suggest buying the special RG59 cable stripper though.
If you don’t want to buy the crimp tool then for screw-on connectors see this video where he also shows you how to split out the power cables on the shotgun cable (he calls it a Siamese cable)
Most videos don’t show connecting up the power because supposedly it’s ‘trivial’ to expose the conductors and either screw into a terminal or just twist them together (and wrapped in tape) onto a Pre-made tail.
