I must admit I find this situation bizarre, received my 3080 today and fitted it. It really is a magnificent piece of kit, yet its so cheap for what it is, the contrast between the fe direct market and the rest is huge.
paid for Saturday delivery ?
Glad you like it! It's a cracking card though you should be looking at roughly 3x the perf of the 970.. even a 1080 non Ti is roughly 2x 970 and the 3060 Ti is another 60-70% faster than the 1080.Yay! My 3060ti is here!
It's way quieter than my old 970. Also, doubled the fps in my quick far cry 5 benchmark.
Glad you like it! It's a cracking card though you should be looking at roughly 3x the perf of the 970.. even a 1080 non Ti is roughly 2x 970 and the 3060 Ti is another 60-70% faster than the 1080.![]()
..and the 3060 Ti is another 60-70% faster than the 1080.![]()
I think you're getting mixed up with the 1080 Ti..That's standard generational improvements from yesteryear. Typically 20-30% is the uplift on CPU/GPUs.
So 1080 > 2080 > 3080 should be around 60-70% (if buying the 3080).
The 3060Ti is essence a cutdown 3070. Both these cards are inferior to the 3080 but a notch down so again you would expect it to be faster than a 1080. I am not sure the 3060Ti is that much better than a 1080, I would realistically put it about 25% but obviously you can call in DLSS or RTX which is nice. If you own a 1080 selling it would fund a lot of the new card so there is that. Paying £370 for 25% used to be shockingly poor value.![]()
3060 Ti is around 50-70% faster depending on game vs 1080 none Ti
Recieved my 3070
As replacement to 2070super, seems to deliver around 30% more performance at same power.
The quiet cooling touted in reviews, not so quiet in my cramped case, hitting 2200 rpm. But as it dumps some of the heat outside, temps in case are actually better.
Will be playing with undervolting next, initial base level at 0.7V is impressive 1535 MHz
Actually no, I tried and it wouldn't let me select it.paid for Saturday delivery ?
Lol all you people moving from 2070supers etc, I'm sat on a 980TI which tbh is only recently showing its age since I bought the 38" Alienware. I've been trying to buy a 3080 for the last 10 months, I'm never in a position to be able to buy one when they release a batch.
I've a new case sat in a box for the last 12 months because I can't buy any wretched parts lol.
My phone goes beep beep so no need to stare at it
You can also install Telegram client on computer so you'll see the popup while you're working. Depending on IT policies but my employer is pretty laissez-faire.
3060ti is way faster than a 1080, probably more than twice as fast.
Recieved my 3070
According to tech power up the 3060ti is 49% faster than the 1080.
Look at the relative performance chart here
https://www.techpowerup.com/gpu-specs/geforce-gtx-1080.c2839
Depending on game.. overall I dont think its as much as your stating but Im happy to be proven wrong!![]()
So a normal 3060 is slightly worse than a 1080ti. Without using DLSS. Use that and it smokes it especially dlss 2.
So the 3060ti without looking at benchmarks I'd say is slightly faster than a 1080ti therefore significantly faster than a 1080. That's without dlss 2.
The best card IMO of this generation is the 3060. DLSS 2 and tweaked settings means it should run anything even at high Res and FPS.
I dont think you even read my post a couple up before that Sonny: #9384
