they haven't for Rocket Lake. Substantial jump over Coffee Lake in CB single thread, almost no gain in gamesSingle thread numbers translate pretty well into games
So it really depends on what changes drive the single thread improvement
Single thread numbers translate pretty well into games though and 810 ST is massive
Doesn't that reflect the core config though, rather than an indication it's worse than rocket lake?Alder Lake is hungry!
take the 11900k's peak and add 50 to 100w to it
Alder Lake CPUs have 50 to 100w higher peak power draw than Rocket Lake
https://www.tomshardware.com/amp/ne...mands-28-higher-peak-current-than-rocket-lake
Boosty burst or bust!
All good news for power supply manufacturers. After the bursty behaviour of Ampere, they now get sell supplies designed for the bursty behaviour of Alder Lake!
So a rig which pulls 500W averaged per minute, might need a few milliseconds burst of 800W, or similar but the supply has to recognise this isn't a fault and not to trigger the over current protection. Sound like the percentage spent on PSU when budgeting a computer build just went up again. OEMs likes HP and Dell will probably just disable PL4!
Actually, the big box suppliers like Dell, HP etc, while they have been getting eveything else wrong (see especially, CPU cooling, case airflow, any type of expandability or compatability) have been using decent gold-rated PSUs for their better machines & generally, their PSUs have been the only decently specced thing in their crappy machines for years & years. I guess they learned from all the RMAs in the 2000sThe OEM are already facing higher power supply costs, due to new efficiency laws in the US, new pre Builth have to use a minimum of a gold certification PSU - power supplies is one area where OEM's have traditionally being able to cut costs to improve margins but not so much anymore as they have to use energy efficient units
Getting your CPU to the top of performance graph is all that matters for Intel and tbf that's not a bad strategy and helps enormously with marketing.It wasn't as if rocket lake was remotely power efficient in the first place!
Nasty.
Perf per watt will be awful!
It was always 2022. Desktop 12th gen isn't due until the end of this year and is rumoured to be a paper launch anyway to steal a bit of bar chart and marketing thunder before AMD do something. First to DDR5, first to PCIe Gen 5 despite the former being expensive rubbish at launch and the latter offering zero benefit, especially as Intel won't be using it for storage where it actually matters.No release date yet ? I hope it doesnt get delayed into 2022 even though im almost certainly not going to buy it unless there is a massive performance leap
Actual volume is suggested as Q1 2022, by which time AMD will have the 3D stacked Zen 3 revision out, more than likely taking all the bar chart numbers back.
The leakers are claiming the 12900k beats the 5950x in multithread benchmarks.
But it's difficult to ascertain if its accurate and also if its an apples to apples comparison. I suspect not because the 12900k system is using DDR5 memory which in many cases would give it a leg up against DDR4 system like the 5950x is limited to.
It is possible that's Windows 11 and Intel's new scheduler combined with this big.little architecture has in fact made a massive improvement to multithreaded system performance but it could just as easily just be the DDR5 that's doing it - only time will tell.
Either way it's still impressive. The 11900k has about half the multithread performance of the 5950x, so if by adding 8 little cores clocked at 3.7ghz along with a new scheduler, some IPC improvements and DDR5 has allowed it to more than double it's multithreaded performance then that's amazing.
The 5950X is nearly 2X the performance of my 5800X, is that impressive? I would be more impressed if they both had the same number of cores, the fact that the 5950X has 16 and the 5800X only 8 makes that less impressive.
You buying a full CPU would be impressive![]()
Even 10900k [...] once you limit it's power draw to 140w max, it shows itself to be a decent budget option vs superior 5900x chips. (Arguably even 5800x)
The biggest thing that gets the cut is that Intel is losing AVX-512 support inside Alder Lake. When we say losing support, we mean that the AVX-512 is going to be physically fused off, so even if you ran the processor with the E-cores disabled at boot time, AVX-512 is still disabled.
