I deployed a BIOS update to all the HP workstations at work the other week. Was quite nerve wrecking to watch 100+ update at the same time. Solved a few niggling issues like the computers not waking up in the morning, inconsistent BIOS passwords etc. No failures.
On my own hardware, usually after the "honeymoon" period is over I never look at it again, unless changing CPU or there is a known issue that can be solved
So you updated 100 + computers in one go ? how does that work ?
I am on z390 and still getting bios updates in 2021 so just update to the latest one when they become available.
Set up one as intended, including auto update BIOS, run the HP BIOS Configuration Utility (HP BCU) and export a text file of the current config (and encrypted password file), package and deploy via SCCM/Endpoint Configuration Manager with a script action to run the .exe on the target machines/device collections
Yes!
I really can't understand why people are so deathly afraid of doing it! Recently had the conversation with some friends and all I was hearing was "No don't it, you'll will brick your board and void the warranty"
