So in order to disprove my comment you go ahead and post a benchmark where things are not set equally? Good job slick, you just earned the "Score in your own goal" award.
I wouldn't expect a 3070 to run it well at 1440p at maxed settings. That's why I purchased a 3080.
i want to make a clarification...3070 can't even reach 60 fps most of the time at native 1080p lmaoat 1440p native with normal rt settings it wont punch anything above 40 fps unless you look at sky or be in nomad area...
its hilarious tbh. "good" rt performance yet its not. even a 3080 wont push a 60 fps at 1440p native with rt in cyberpunk.
The game doesn't run that great with RT features off either. Not sure what is up with the performance of the game for some people though
That's the problem.. it isn't, RDNA2 ray traces at RTX2000 levels which was discounted by HUB along with RT on the 3000 series (remember the Nvidia debacle ?). Now AMD have the hardware they are limiting the cores of the 3000 series and suggesting that RDNA2 is equivalent.. terribly misleading.
When RDNA3 and rtx 4000 series release and RT gets taken to the next level the people who bought an RDNA2 card based on the above premise are not going to be happy.
And don't think that graphics are now limited to what a console can produce, that's a joke.
Simple way to solve this, if amd cards are so good at raytracing now then getting posting in here:
https://forums.overclockers.co.uk/t...eature-test-port-royal-bench-thread.18838895/
Don't know why people can't accept the fact that RDNA 2 is just simply not as good as ampere for "ray tracing"...
Plenty of material out there showing the full picture and not heavily altered tests and extremely limited tests at that. Might as well have just reduced them to console settings and done a comparison with the ps5 and xbox...
Also, comparing to the tessellation fiasco with crysis 2 and witcher 3.... Not even in the same league, the heavy tessellation had literally no benefit to IQ where as ray tracing effects do.
Good points there tbf.
People give a lot of **** to turing owners who upgraded to ampere cards for the increased ray tracing performance, wonder if we'll see the same come the next lot of amds cards![]()
HUB like tossing out the occasional click bait video, the previous one was the OMG a 65w TDP CPU is only running at 65w on cheap B560 boards unless you change the power limit yourself.That's the problem.. it isn't, RDNA2 ray traces at RTX2000 levels which was discounted by HUB along with RT on the 3000 series (remember the Nvidia debacle ?). Now AMD have the hardware they are limiting the cores of the 3000 series and suggesting that RDNA2 is equivalent.. terribly misleading.
You wouldn't want that as the 3060 would just take an even bigger beatingMight as well have just reduced them to console settings and done a comparison with the ps5 and xbox
. Ampere isn't known for being very scalable with performance at lower than 4k resolutions. But I'm sure you and the gang are going to make an argument for running these 1080p cards at 4k just to eek out a win, playability be damned
.Your completely missing the mark here. Nobody has said that AMD has perfect raytracing performance that match the raw horsepower of Ampere. They are on gen one of their implementation. Nvidia is on their second. However, recent titles that doesn't overuse RT is very playable on AMD hardware. So yes it has improved. Then again, the first RT titles was made through the nvidia developer "take money, use blackbox software with zero compatibility, gimp game" program aka GimpWorks. Didn't the 2080ti have horrible 1080p RT performance in battlefield to the point where DICE had to tone down the RT effects to get a workable result?
Heavy RT is the same as with tessellation, very little visual gain for a very steep performance price, ampere or not doesn't matter. Look at the 3080ti running Control 4k native High with only medium RT, still cant hit 60 and that game is so heavily sponsored by nvidia it's almost embarrassing it doesn't do better.
You wouldn't want that as the 3060 would just take an even bigger beating. Ampere isn't known for being very scalable with performance at lower than 4k resolutions. But I'm sure you and the gang are going to make an argument for running these 1080p cards at 4k just to eek out a win, playability be damned
With every new ray tracing application, the promise of RT cores 2.0 and tensor cores 3.0 is put to the test again. The ART-Mark shows what Control, Minecraft RTX & Co. could only sketch out blurred, namely where the journey could go in the future: The more complex the ray tracing in space, the better Ampere performs. The extent of the difference depends on the implementation, with the ART mark being pushed to the limit with the help of Unreal Engine 4. The exaggerated use of rays at high settings to represent reflections in reflections, which cause a multitude of bounces - reflected light - shows the graphic potential of the technology. If you compare Turing-TU102 as 1st-Gen-RTX with Ampere-GA102, Ampere is up to a factor of 2.7 faster. If you only use the (halfway) smoothly displayed settings, in this case "RT High", it is still a factor of 2.2 and thus significantly more than in all current raytracing games. That is certainly due to the scene
If you compare Nvidia's first RT generation with AMD's first RT generation, the result is a tie. In fact, the RDNA-2 GPUs, better known as the Radeon RX 6000, can handle more complex ray tracing calculations better than Turing. The RT High preset of the ART-Mark runs just as well on a Radeon RX 6900 XT as it does on a Geforce RTX 2080 Ti. Compared to an RTX 3060 Ti and above, no Radeon herb has grown with raw ray tracing. AMD will tackle this backlog with RDNA 3, that's for sure.
a 3060/3060ti/3070 would have been a better choice for you to pair with your "old ivy bridge system". Bit of a waste buying a 3080.I wouldn't expect a 3070 to run it well at 1440p at maxed settings. That's why I purchased a 3080. I almost went 3090 but sanity told me that I wouldn't notice a difference at said resolution. Looking at the heat/power draw issues I'd say I dodged a bullet.
What a silly answer. You argue about the 3060 then when pressed into the corner you dodge it. I think @Phixsator can throw back at you "I feel my original point has been proven here."
Imagine talking about console/AMD performance limitations when you do things like that.![]()
No u![]()
The cards are ok it's the price which is the issue, one should cost £250 and the other £280.And nope, 3060/6600xt is not a "PC 4k card", want a true 4k pc experience, 3080/6800xt or higher is the way to go. I rather get a ps5/xbox than a 3060/6600xt card.
That test is more close to the Minecraft type of RT and not CP or ME which are still hybrid RT games. A more appropiate test to judge the hybrid RT performance is the Port Royale benchmark and yes Ampere is like 25% ahead in there.Simple way to solve this, if amd cards are so good at raytracing now then getting posting in here:
Few things -
- Do you think I wish to remain with a 3770k now that software is starting to tax it?
- Do you think a 3060/3060Ti/3070 will out perform a 3080 with a 3770k.
- Do you think a 3060/3060Ti/3070 will out perform a 3080 with an up to date CPU?
- Do you think the best place to promote consoles is an enthusiast PC forum?
But this has nothing to do with the low end 3060 or 6600xt, these cards are not able to run any form or RT at high settings/resolutions. HU were right to reduce some settings to the point where the game becomes playable, there is no reason to show that a card gets 10 fps but it is still better than the other that gets 5 fps.![]()
