- 21 Jul 2005
- Officially least sunny location -Ronskistats
I made my point regarding a misleading video.
Poster is then mislead by video.
What is your problem now?
See this guys post below. Pretty clear. You then went on to say you bought a card higher up in the tier to cope with RT (as cards in this post arent really meant for it). If you cannot understand that then its done.
That test is more close to the Minecraft type of RT and not CP or ME which are still hybrid RT games. A more appropiate test to judge the hybrid RT performance is the Port Royale benchmark and yes Ampere is like 25% ahead in there.
But this has nothing to do with the low end 3060 or 6600xt, these cards are not able to run any form or RT at high settings/resolutions. HU were right to reduce some settings to the point where the game becomes playable, there is no reason to show that a card gets 10 fps but it is still better than the other that gets 5 fps.![]()
Also.. this:
The first 3 are questions you should have asked yourself before buying a 3080.
glad I could help
- Maybe you don't, but if you upgrade in 12 months that's almost 2 years of wasted GPU power and console like performance limitations.
- No, but at 1440p (and DLSS) the gap will be much smaller in open world true NeXt GeN games.
- No, but you don't have an up to date CPU. If you did you would get the full benefit of the 3080.
- No.
