- 24 Sep 2015
- To be built between April 2022 and April 2025
I wouldn't read too much in to that. It says April 2021 - December 2026 for me and I've had FTTP since June last year.
I’m surprised that pole wasn’t declared unsafe and marked for replacement tbh.
fttp is not pole based ??? it's all underground as far as i know .. non copper ?
It can be fed via poles or underground. Poles will be the only option if there’s no underground infrastructure due to the costs involved in putting in new ducts etc.fttp is not pole based ??? it's all underground as far as i know .. non copper ?
this i did not know living in a city area .... thxIt can be fed via poles or underground. Poles will be the only option if there’s no underground infrastructure due to the costs involved in putting in new ducts etc.
What's the current cheapest 1gb FTTP openreach provider? They all seem around the £55/£60 mark
If you are with EE for your mobile network then going through them can be competitive.What's the current cheapest 1gb FTTP openreach provider? They all seem around the £55/£60 mark
My FTTP would disagree with you . Cambridge fibre just use the old BT pole infra where possible to make rollouts a) faster and b) cheaper/less invasive.fttp is not pole based ??? it's all underground as far as i know .. non copper ?
Am I looking at that wrong or is that flowers below the little black box? Or it's next to the street light...
Just the angle. There's another pole behind it in the scene, the street lamp pole, that is the one with the flowers attached to it in a basket or sorts. You can just about see the silver pole behind the wooden one in that image.
