Palit RTX 3090 GamingPro, peasant edition.
XE bottom, PE side and top.
Sorry for the fingerprints all over the rads and blocks.
Waiting for the ZMT to replace the clear tubing.
Love that blue colour ...
Not really impossible, they can be found from people that purchased them and regret buying them and if you know where to look they are up for sale at what they paid for them and even less sometimes because they state the unit has bad coil whine or they damaged the original cooler when trying to add another cooler. After reading all the complaints on the EVGA forums about the KingPins, FTW3 and other models this generation, I wouldn't risk even half price on one. They can keep them.lol $600 for a gpu block, for a card that is impossible to find anyway
The waterblock looks really nice but no chance is it worth $600 and I don't watercool anyways, just thought Kaap would get a kick out of it and have a little laugh at the silly price too.
Hi to all!
Does anyone has an ups with your system?
I´m having some troubles using it alongside my RTX cards.
Anyone with an EVGA XC3 (or any other AIB) what is your core boosting to? I've seen the 3090 FE sit happily at 1900Mhz, while a friend I play online with and his sits at 2000MHz at 0.925V. Mine however won't get above 1800Mhz even with the power limit at max
Port Royale BenchmarkWhat game, settings, rtx, res, gpu temps, resizeable bar?
I've noticed the core clocks can vary wildly from game to game, depending what sort of load is on the card, even when it's 'working' at 99%.
Btw, I don't have an evga 3090, just the founders edition.
Weird how this didn't affect the FE however.Nice one. I've also noticed that Nvidia's power settings don't allow the core boost to maximum unless it's set to maximum! I would expect the Normal setting to not only downclock when not needed, but also to hit maximum when required. Shame, as we don't need the GPU running at max all the time.
Anyone with the EVGA XC3 3090, how are your temps? Mine hits 75°C pretty quick even with the fans ramping up to 70%. Seems a tad hot to me but thought I would see what others are getting
Yes sorry should have said.Core temps?
