The fact little Johnny won't be getting an Xbox for Christmas if China invades Taiwan is the last the thing we should all worry about in such a situation.AMDs success is really down to TSMC. Their Gpus while good only match Nvidia on a far worse Samsung node and they also have a node advantage against Intel.
If China invades Taiwan then what happens to AMD?
I don't where you getting this assumption that Samsung's process is 'far worse' then TSMC, Ampere draws many parallels to GNC in terms of design rationale which is focused around the data centre. Cramming all those cores into the chip creates issues with utilisation and occupancy which has meant Nvidia having to ramp up the core clocks resulting in the GPU having a massive power draw and using GDDR6X isn't helping matters either in terms of efficiency. None of those things have anything to do with Samsung's process, if they tried to build a GA102 at TSMC if would cost Nvidia a lot of more money to make meaning even more expensive GPU's (Nvidia won't accept a lower margin product).
