Man of Honour
- 23 Mar 2011
- West Side
Not allowed to name competetitors as per forum rules, sorry.Out of interest Mick where have you seen this, is it reconditioned with the warranty or new?
Detective skills activated.Ah did not know that, all understood
Yep .Ooh that's a good find, hadn't realised that place would have such relatively reasonable prices on old gpus and do a 24 month warranty! Having a warranty does make the prospect of an older card much more attractive.
Good news .Morning all,
I have managed to locate the pre used GTX970's with a warranty so all good there. This may seem a dumb question but I am out of my depth with graphic cards so can I just confirm.
Will any GTX970 card fit my motherboard which is a Gigabyte GA-F2A78M-HD2 or do I need to by a Gigabyte GTX970?
Good news .
You dont need a new motherboard yours had a pci express slot for the gpu .
What case do you have as you need to make sure the 970 isnt to long, the palit 970 is 247mm in length.
Ok .Thanks for confirming the MB question Mick, the case is large but I will switch off, open it and have a measure inside. I am confident there will be enough room but will double check.
the gpu will be powered by the psu, not the motherboard..the leads should go from the back of the psu directly into the gpu. (Nothing to do with the motherboard)
Your psu will have a few 6+2 pin connectors, probably tucked out of the way if they were not used previously or in it's box if it is a modular psu. You need to fit a 6+2 pin lead to the 8 pin socket on the gpu and just the 6 pin part of the lead (just tuck or cable tie the +2 pin part out of the way) to the 6 pin socket.
That's a big upgrade from a GT730 and you will be able to turn the detail sliders up a lot. That cpu is probably going to hold things back but I would hold off on upgrading the cpu/motherboard/memory for now until AMD and Intel have launched their new cpu's and sockets. Even if you don't want to buy the new cpu's you should be able to get a good deal on a current bundle from people who are upgrading.
