- 27 Apr 2007
You can have the HEDT goodies with the right X570 board.
Just saw this. Intel and Microsoft worked together on Alderlake / Windows 11, now this happens to all Windows 11 compatible CPU's from AMD
https://www.tomshardware.com/news/a...N_9I5EXQlcp1YG2yPZ3itDu3-OyHiNXhtct4TiEkh7Bac
Honestly this would be my thought. After all it is a product of MS and Intel working side by side but it is possible i am on the look out for black helicopters for no reason. I am sure it is not beyond Intel though given their proven track recordHow in the world does this get through testing and not get fixed by release? It can only be intentional surely?
<tinfoil hat mode>What's the betting MS patch it the day after the Alderlake reviews come out, most/all of which bench on W11...</tinfoil hat mode>
Most reputable reviewers will twig the performance difference on Ryzen CPU's Win 10 and Win 11, AMD will also no doubt tell them about it. So at the very least they will make this perfectly clear in their reviews, or preferably not add Ryzen to the Win 11 slides at all and explain why.
As for me, i haven't installed it and i'm not going to until after all patches.
Edit: you would think that MS would work with all vendors to make sure everything works as it should, how did Intel get that exclusively?
Looks like pretty strong SC performance, will have to wait for other benchmarks though.12700k benchmarks leak
it matches the 5900x in multi core and beats it in single core by 25%
https://wccftech.com/intel-core-i7-...faster-than-amd-ryzen-7-5800x-core-i9-11900k/
As for prices, various store listing leaks indicate the price is about 500 Euros
, single core performance is not important.
Trolling or just plain dum?
There are so many algorithms that cannot be parallelised.We live in a highly threaded world, where the single core performance is not important.
It's very hard to tell these days.
Single core performance is not important? If it's not important then we should keep the same performance per generation and just keep adding cores? Speed of the cores is very important..
