- 21 Oct 2011
- ST4
Tabby's Star is back at it again.
A reasonable low prices telescope - I'll let other spec an example - will also give you a reasonable look at Jupiter and Saturn too.What’s a good budget telescope for looking at the moon? I had a celestron I think it was a few years back it was brilliant.
will go second hand just need some guidance on what to buy.
tia
tia
The accretion disk surrounding the star PDS 70, but if you look at 3 o'clock you can see an exoplanet (PDS 70c) with it's own disk of material which will most likely go on to form a moon(s) around said planet.
Why is the star dimmer than the planet and disc?The accretion disk surrounding the star PDS 70, but if you look at 3 o'clock you can see an exoplanet (PDS 70c) with it's own disk of material which will most likely go on to form a moon(s) around said planet.
I thought that was Saturday US time.. they’ll be busy prepping the next steps for first light
