- 21 Dec 2019
- Planet Thanet
I don't actually remember where I got the firmware
Couple other ideas though
What power plan are you using?
If not high performance try that
Also in power plan look at advanced settings
Then make sure pcie link state power management
Is switched off
And lastly in power plan check if fast start is turned on
That may depend whether you use hibernation
I delete my hyberfil.sys file
Is switched off
