Not sure if anyone is still reading this/interested in progress but will add an update for my own sanity:
Next on the list was putting up the Vapour barrier, which qas a fairly quick job with a wacker tacker & staples. I also filled the small voids at the edge of the room with loft roll/rock wool cavity insulation.
The next stage was to install the counter battens to give a service void for cables and attach the plasterboard to:
I then contacted my electrician and got him to do the first fix electrics. When he arrived I still hadn't fully decided how I wanted the room laid out, but made it up quickly and should hopefully have enough.
I've got cabling for:
So that's where I currently am up to. I now need to consider network. I want to have Ethernet and Wifi out here. I haven't done anything like that before, but suspect I will dig a trench from the side of my house to the workshop in my garden and bury some ethernet cables in some conduit. Once inside the workshop I'll need to run them to the office part and decide if I want wall sockets/switch/etc. From memory I've got a Wireless AP but is PoE so will need a PoE switch as I doubt my EE Home Hub will offer that!
To do list:
Any feedback/questions welcome.
- 4x LED Downlights (these will be dimmable)
- 4x Double Sockets (2x on desk side, and 2x below window)
- 1x Single socket for a TV above Desk area (opposite wall to window)
- 1x Single socket on large back wall for panel heater (will be a Wi-Fi controlled heater so I can turn it on/off remotely/on a schedule)
To do list:
- Finish Alliminium taping.
- Run Ethernet cables
- Plasterboard
- Electrics - Second fix
- Tape and join
- Paint walls (White)
- Decide on what flooring to go for
- Order/fit panel heater
- Fit door lining and door
- Skirting board/architrave/coving
